You won't be able to without re-encoding. You do not have 3 of the same files.Appreciate your input but it does not help me to resolve my problem.
Results 61 to 71 of 71
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
Encoders in general are not necessarily deterministic because of threading
Technically you shouldn't need to match GOP characteristics such as length, but they are different between the two B's according to that sparse mediainfo report. I guess you might have a better chance if you matched everything
You need a stream analyzer for more detailed information. I mentioned a free one earlier h264_parse. -
Megui (which uses x264) does expose them, but you cannot use it because it only uses MBAFF, not PAFF. Your other segments are PAFF
Your best bet is to use the same old AME version. The higher end mainconcept versions in various software expose advanced settings e.g. totalcode.
Mainconcept AVC is what AME licenses, that's your best bet for compatibility
Any differences that might explain why B0 works, but B1 doesn't
I've not tried any stream analyzer. What should I look for? -
You have stated:
So where are your source files? The m4v files have been produced by AME, that is, something was encoded by AME; what was this something? Put the 3 source files together and then encode them into one output. Use an NLE to join the source files and output losslessly if you need and import into AME. Since AME used, import the source files into Premiere Pro and export from there. If you don't have the original files (where did they come from), then you have no control or idea over HOW they were encoded. Did you encode them? If so, then use the originals.I have 3 m4v files, A, B, C, all produced by Adobe Media Encoder, plus 1 AC3 files. They work fine in Encore. A, B and C together forms a single timeline.
What files did AME use to create the 3 m4v files?Last edited by ron spencer; 28th Jul 2016 at 21:22.
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Well, that is a drag....seems to me that they were not exported in the same fashion. This is a lesson...export your stuff altogether, either as a lossless format and then encode, or encode from timeline, and of course keep your source files. Don't mean to sound mean or anything, but I've made the same mistake before. I think you may be out of luck and may need to reencode the lot. Not sure what else to say really.
Video to Video, a free download can do it. I have used it before with good results.
Easy to do.
Replacing multiple M2TS files with one large M2TS - possible??
By kpic in forum Authoring (Blu-ray)Replies: 0Last Post: 1st Nov 2014, 00:55 -
tsMuxer and joining m2ts files
By fkasparek in forum Blu-ray RippingReplies: 13Last Post: 12th Jun 2014, 12:07 -
m2ts joining issues
By MarkV in forum Authoring (Blu-ray)Replies: 3Last Post: 20th May 2013, 11:58 -
Splitting/Joining AVCHD video files (m2ts)
By glenpinn in forum EditingReplies: 17Last Post: 19th Sep 2012, 11:13 -
Joining two m2ts-files from two blu-rays (LOTR extended edition)
By NTC1985 in forum Video ConversionReplies: 6Last Post: 28th Aug 2011, 17:44
