Hi,
I have 3 m4v files, A, B, C, all produced by Adobe Media Encoder, plus 1 AC3 files. They work fine in Encore. A, B and C together forms a single timeline.
Encore then produce 3 m2ts files when I do a Blu-ray folder build. Each of these m2ts file can be imported into Encore and does not require transcoding.
However, I can't find any tool that can join (without transcoding) these 3 m2ts into a single one the Encore will accept as a valid for Blu-ray (no transcoding).
I've also tried to deal with the m4v files directly but there appear to be less tools for that format.
Tools tried:
tsMuxer: corrupt the middle segment after the join (mosaic and jitters)
VideoRedo: transcode
SolveigMM: no transcode, but output requires transcoding in Encore
Is there any other tools that I can use to merge them?
Results 1 to 30 of 71
video redo cam handle m2ts files
use the quick fix tool on all streams, then join them -
Does anyone if it produces m2ts file that are accepted by Adobe Encore with transcoding?
Thanks -
Video redo, will NOT transcode the streams
they will be same streams, with any 'Glitches' fixed so the stream is clean
there should be NO prolem with adobe, if it is accepting your current source streams
of course. idk where your m2ts come from
mine come from my PVR
and i dont use adobe encore -
Does Encore accept your individual original files without requiring transcoding?
If so, just join them in the timeline. -
I think he's saying number two file has glitches which Adobe tries to fix by transcoding but everything gets messed up
I tried VideoRedo. Open a video, add to joiner. Add 3, then Save Joiner
It took a long time and here is the report
Video output frames: 154624
Audio output frames: 161230
Processing time (secs): 9668
Processed frames/sec: 15.99
Actual Video Bitrate: 20.69 Mbps
PTS underflows: 160898
Max PTS underflow (ms): 886412.00
It's clear that it re-encoding the video (and resulted in a different bitrate as well).
Do you know I can do it to make it not to re-encode?
Thanks -
Sorry was doing the experiments.
However, I can't find any tool that can join (without transcoding) these 3 m2ts into a single one the Encore will accept as a valid m2ts (no transcoding).
Tools tried:
SolveigMM: no transcode, but output requires transcoding in Encore -
I'd there some reason these files must be joined before encore?
I assume you want to author a Blu ray disc
I have never authored Blu ray
But on DVD three files can play as one continuous file even if they show in the main menu as separate selections -
I would try ffmpeg concat demuxer first
https://trac.ffmpeg.org/wiki/Concatenate
If that doesn't work, I would try joining elementary streams with dos
Just because 3 separate files are BD compliant individually, doesn't mean they should be when joined. The reason there might be a buffer overflow or underflow. For example a bitrate spike in the beginning of the middle section, might deplete the local buffer level, causing a stutter. You should encode it as one BD compliant video in the first place if that was your goal
EDIT: ok , I see that it was Encore that produced the 3 m2ts streams for a single timeline. That should not have been a problem. But on the authored disc, it should work fine in a BD player - there is no reason to join them . If you already have the authored BD folder, why are you trying doing this ?Last edited by poisondeathray; 22nd Jul 2016 at 21:36.
The Encore timeline has 3 m4v files on the video track. When it builds BD disc, it does not join them. During playback, the pause b/w the segments is unacceptable because it's in the middle of a scene. The source material is no longer available. I have been trying to merge them to avoid re-encoding as the picture appears to degrade quite a bit.
DOS copy does not work. The playback will contains some corrupted frame and Encore does not consider it valid for BD either.
Does ffmeg produce file that acceptable by Encore? I have never used it. -
only if the files were compliant in the first place - because you're not re-encoding when using concat demuxer
But even then , it won't work for sure - because of the buffer issue I mentioned earlier.
How are you checking playback ? How are you seeing the pause ? Is this software, hardware player & physical BD - what is the setup ?
If it's on a physical BD and BD player - it sounds like encore goofed up. It's error checking and resiliency are not that great - it lets things pass through that it shouldn't (that fail on a BD verifier) . So the problem was probably already in your m4v files -
ffmpg is able to join but the output is not compatible with Encore
Input #0, concat, from 'ffmpg_join.txt':
Duration: N/A, start: 0.000000, bitrate: 192 kb/s
Stream #0:0: Video: h264 (High) (HDMV / 0x564D4448), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
Stream #0:1: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s
[mpegts @ 0000000000b32c40] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead.
Last message repeated 1 times
Output #0, mpegts, to 'ffmpeg.m2ts':
Metadata:
encoder : Lavf57.42.100
Stream #0:0: Video: h264 (HDMV / 0x564D4448), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 29.97 fps, 29.97 tbr, 90k tbn, 90k tbc
Stream #0:1: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, 192 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
[mpegts @ 0000000000b32c40] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly
[mpegts @ 0000000000b34400] PES packet size mismatch:58:50.44 bitrate=21590.8kbits/s speed=30.5x
Last message repeated 2 times
[mpegts @ 0000000000b34400] PES packet size mismatch:25:50.86 bitrate=21172.5kbits/s speed=31.6x
frame=309296 fps=1898 q=-1.0 Lsize=13325817kB time=01:26:00.03 bitrate=21155.9kbits/s speed=31.7x
video:11948440kB audio:123128kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 10.390110% -
When you tried dos, did you to it on the m2ts or the demuxed video and elementary stream?
All authoring tools work best with elementary video (no container). -
video redo test
i just did a test with (3) mts files recorded at xmas, NOT hi-def 720*480, 3 (1) hr files
it took 77 seconds to join and used fast frame copy and removed some 2000+ audio and video sync frames ?
i did a second test, hi-def test (3) mts files from the x-files special 1280*720, 224 seconds to join
I think you have major problems with your files, they are not identically sourced, not identical specs, or video redo would handle this quickly and easily -
Sounds like your middle file is very different from the other two. A pause in playback from a single timeline is most likely due to a different framerate and/or raster dimension, or it is somehow damaged.
The middle segment is something I can change (short so transcoding is acceptable). This is the same as the other 2 pieces, as far as Adobe Media Encoding setting is concerned. If I compare them in MediaInfo, aside from bitrate, the only difference I can see is the middle segment has GOP while the other 2 do not.
Format settings, GOP : M=3, N=29
Does GOP has an impact? If so, what can I do about it?
Thanks -
All Br files have GOPS.
Are you using any of the BR presets in AME? See if that works before trying to customize it.
Are you trimming your middle file? Try doing that in AME rather than Encore.
You have a lot of moving parts here, so apologies if I'm not keeping up.
You've negatively affirmed that your frame rate and raster size match, but yo still haven't told us what they are. -
Here is from MediaInfo. I don't want to re-encoding the long video (quality degradation is significant). I can re-encode the short one. There is no trimming. Just to join them. I think Adobe Encore is quite picky.
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 58mn 55s
Bit rate mode : Variable
Bit rate : 19.5 Mbps
Maximum bit rate : 35.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 (30000/1001) fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.314
Stream size : 8.04 GiB (95%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709 -
Since we're trying to compare 3 files, including partial information from only one isn't completely helpful.
There's nothing that looks particularly wrong with that file except it normally would have GOP information. The GOP you posted earlier is somewhat unusual, M-2, N=15 is more common for NTSC.
You're correct in saying Adobe Encore is quite picky. That's a good thing. -- It insists on meeting BR specs. -
Here are the other 2
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 25s 158ms
Bit rate : 3 989 Kbps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.064
Stream size : 12.0 MiB (91%)
Video
Menu ID : 1 (0x1)
Format : AVC
Format settings, GOP : M=3, N=18
Codec ID : 27
Duration : 26mn 38s
Bit rate : 18.5 Mbps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.298
Stream size : 3.45 GiB (95%)
I don't use Encore
But it's a good bet that unless all three videos match specs there is no way to avoid transcoding
And these do not match
Your choices are to individually transcode each video to an acceptable BR spec before joining
Really I don't see any other choice,
Maybe somebody with more Blu-ray expertise knows another way -
Each individual file can be imported into Encore without any transcoding. So their spec are all correct. The problem I'm trying to solve is to create a single file with all 3 segments joined.
No!!
You are miss understanding that situation
Have you tried creating your Blu-ray file with each one by itself
Just because encore accepts it for import does not mean it meets output specs
You want to make one file
All files have to have exactly matching specs GOP's audio, everything or they cannot be joined into one file
There fore they all get transcoded into one file with one spec during encore output
Miss matched files will not be joined
You transcode before encore or encore will transcode them
And you have already seen what happens when encore does it
Your mistake is thinking mis matched files can be joined together without being changed to match each other
You might as well be trying to join 720p and 1080i
The fact they are all 1080 is over shadowed buy the fact the other specs Do Not MatchLast edited by theewizard; 23rd Jul 2016 at 21:40.
I can
a) create a single timeline with all 3 video, burn BD disc and play it in BD player
b) create a BD disc for each segment, burn BD disc and play it in BD player
So each individual, or 3 combined in Encore timeline all match BD spec and can be burned and played successfully.
I am not quite sure of what you are mentioning. Do you mean video must have the same GOP settings? If MediaInfo is not showing it, how can I tell?
You also said audio (in GOP's audio). Does audio play a role here?
Thanks -
I said all specs
The audio spec of each segment should be the same ,sorry I forgot the comma separating GOP's and audio
And do you mean burn a data disc with video file?
That is not the same as creating Blu-ray movie disc
You are the one that said encore will not join them with out transcoding
Is your time line video disc transcoded?
Yes? Proves what I'm saying
Or this a disc that play three files one after the other, Each one different specs
Afaik a timeline play and a single joined movie file are different things
Like I said i don't use encore
You keep saying encore transcods and you don't want to trans code
I'm saying afaik there is no way to avoid it
It has to happen somewhere in the processes, your files don't match, they may fall within spec but they don't match ,
A video file with changing specs cannot be turned into a movie disc
Separate files with different specs can exist on the disc
But the movie will be one set of specs, variation of video bitrate within certain range is normal depending on picture data
But Gop size and spec and some other data? Will be the same
Some body with more BR experience needs to step in here and help outLast edited by theewizard; 23rd Jul 2016 at 22:13.
Replacing multiple M2TS files with one large M2TS - possible??
By kpic in forum Authoring (Blu-ray)Replies: 0Last Post: 1st Nov 2014, 00:55 -
tsMuxer and joining m2ts files
By fkasparek in forum Blu-ray RippingReplies: 13Last Post: 12th Jun 2014, 12:07 -
m2ts joining issues
By MarkV in forum Authoring (Blu-ray)Replies: 3Last Post: 20th May 2013, 11:58 -
Splitting/Joining AVCHD video files (m2ts)
By glenpinn in forum EditingReplies: 17Last Post: 19th Sep 2012, 11:13 -
Joining two m2ts-files from two blu-rays (LOTR extended edition)
By NTC1985 in forum Video ConversionReplies: 6Last Post: 28th Aug 2011, 17:44
