I have not learned the whole documentation because that would take too much time, which would not pay back, since I don't plan to use Avisynth for much else than assisting the restoration of a couple of videos. The problems I wanted to solve are simple, and based on previous programming experience it should not have caused much problem with any logical, common sense, user friendly programming language. From the runtime environment I have used ConditionalFilter, ScriptClip, ConditionalReader, and WriteFile, but they don't make programing much easier.
How would you solve the same problem using common programming logic with for - next, if - then cycles and branching (in runtime environment - or otherwise)?
Results 61 to 61 of 61
Vegas 13 - move clip frame by frame?
By ricmetal in forum EditingReplies: 4Last Post: 21st Apr 2015, 04:49 -
Premiere Pro: Import/Export XviD & Frame Size Issues
By Cube11 in forum EditingReplies: 11Last Post: 6th Feb 2015, 21:43 -
Editing video frame by frame - less obvious results?
By Free2bme in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jul 2014, 10:00 -
Sony vegas 11 frame-rate
By cojothebro in forum EditingReplies: 11Last Post: 7th Sep 2013, 12:02 -
Frame issues with Vegas 10 pro
By Jon.G in forum Video ConversionReplies: 16Last Post: 3rd Aug 2011, 18:24
