Seems like I finally found a solution that worked. After toying around with all the settings I finally tried setting the VBV Buffer back to 40. I used several different settings to test this and all the test clips I burned worked. Using the same settings with the VBV Buffer set to 0(automatic) gave me the same choppy audio problems. Hope this helps some of you out there.
Results 1 to 1 of 1
Vcd audio problems
By Ak_wf1 in forum AudioReplies: 5Last Post: 26th Nov 2011, 21:19 -
Vcd audio problems
By Ak_wf1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 26th Nov 2011, 20:59 -
Problems with DVD to VCD, including no audio. Help!
By gastrof in forum Newbie / General discussionsReplies: 8Last Post: 4th Jan 2008, 13:39 -
?? Disc problems
By dazzaboy2 in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2007, 13:51 -
Follow up : audio problems with VCD authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jun 2007, 19:34
