  1. Hi
    As topic, I can hear the sound of the video without problem in my computer. But after upload to Youtube/Facebook, it will has problem (only can hear zizizizizizizizi sound).
    I think it has something to do with "fake stereo from a mono track by inverting one channel is the problem."
    But I dont know how to solve it with ffmpeg.
    Any expert here can teach me to correct command?
    Thanks !
    General
    Complete name : C:\a.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/mp41)
    File size : 583 KiB
    Duration : 36s 826ms
    Overall bit rate mode : Constant
    Overall bit rate : 130 Kbps
    Writing application : Lavf56.30.100
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Frame rate : 46.875 fps (1024 spf)
    Compression mode : Lossy
    Stream size : 576 KiB (99%)
    Language : English
    Default : Yes
    Alternate group : 1
    Try reconvert the audio.
    Open the video in for example avidemux. Under video choose copy, Under audio choose mp3(or aac), under format choose mp4, save as a new video.mp4. Check how it sounds. Upload to youtube.
    Aug 2010
    San Francisco, California
    FFmpeg turns out to be a somewhat gnarly command. To use only the left channel:
    ffmpeg -i myinput.mp4 -filter_complex "channelsplit[L][R],[R]anullsink" -c:v copy -c:a aac -b:a 160k -map 0:v -map [L] myoutput.mp4
  4. @Baldrick I have avidemux in my pc, but didnt think of using it. Will try it. Thanks!
    @Jvraines I tried and it works. Appreciate it! If I want to use only right channel (just in case for the future)
    this is the correct command?
    ffmpeg -i myinput.mp4 -filter_complex "channelsplit[L][R],[L]anullsink" -c:v copy -c:a aac -b:a 160k -map 0:v -map [R] myoutput.mp4
    Really appreciate the reply, you used seconds to reply me, but saved me few hours of works..
    I have spent several hours to figure out the problem...
    Aug 2010
    You got it.
  6. Thank you!!!!
    Originally Posted by JVRaines View Post
    You got it.
