Hi. I messed up something and need your help.
I had an long mkv file (avc1 codec) and cut it into a small file using Avidemux without re-encoding it. (copy option)
I played the small video file later and found out that I accidentally chose the wrong muxer.
I didn't changed the muxer option to mkv muxer, so the file was saved using the default opion, avi muxer instead.
As a result, fps of the video is totally messed up.
The problem is , I already deleted the original file, so I can't re-do the cutting process again.
I can load the avi-muxed mkv file into avidemux, save it again using mkv muxer, but fps is still messed up.
Is there any way I can fix it up?
I thought the problem was the container, not the video and audio streams since I used the copy option.
So I extracted those streams using ffmpeg, then re-combine them with mkvtoolnix.
Now the video file works fine, at least for me. -
Thanks for posting the solution. It might help others.
avidemux
By slaughtersr in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2014, 14:35 -
Avidemux 2.5
By didikai in forum Newbie / General discussionsReplies: 5Last Post: 20th Aug 2012, 10:52 -
avidemux
By BaPW in forum EditingReplies: 1Last Post: 3rd Apr 2012, 04:44 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 21:07 -
please help me with avidemux
By phoenix777 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Sep 2011, 05:18
