I wanted to transfer some old VHS tapes to my PC for DVD burning. I tried capturing them from a cheap 4 head VCR deck I own, but the tapes are old and the results were poor. The video transfers were very "shaky" vertically and there were problems with severe color bleeding. So I bought a used higher end JVC S-VHS deck, especially since it came with TBC (time-base correction) and the JVC DigiPure image enhancement technology. The deck I got was the S-VHS capable JVC HR-S9911U. Here's a link to the user manual in PDF format:
http://resources.jvc.com/Resources/00/00/97/82931ien.pdf
The capture card is an older Hauppauge model that has worked fine for years with my cheap 4-head VCR player and still does.
Unfortunately, no matter what settings configuration I try on my WinTV capture card for input channel configuration (NTSC, PAL, SECAM, every variation of configuration parameters with each of those major format, etc.), I can't get a valid picture or audio signal from the JVC deck. Instead what I see in those configurations that do show at least something on the WinTV recorder software monitor window (instead of just black), is a repeating pattern of orderly shapes that if I was forced to describe, look like "morse code". Note, I also did try every different reasonable setting on the JVC deck, and all the RCA jack compatible outputs on the back of it. No luck.
I am trying to figure out how to solve this and I'm wondering:
- Does the JVC put out a digital signal instead of an analog one, perhaps one my WinTV capture card can't cope with and that's the real problem?
- Or is the deck just broken?
I bought it used from a third party and they said they plugged it into their TV and saw a healthy picture.
It outputs a normal analog signal. Do you not own a TV or monitor with composite or S-Video input to determine whether the VCR works?
Game HD capture devices (Elgato, Avermedia, Hauppage) for vhs capturing
By videorecover in forum Capturing and VCRReplies: 4Last Post: 7th Jan 2016, 18:48 -
Sabrent Capture Card: No Signal from S-Video
By PleaseSendHelp in forum Capturing and VCRReplies: 15Last Post: 14th Dec 2015, 21:23 -
VHS Capture issue with Hauppage WinTV-HVR-2250
By Finkswitch in forum Capturing and VCRReplies: 37Last Post: 6th Jun 2013, 21:42 -
No signal at all from Hauppauge Colossus Capture Card
By Rizz1337 in forum Capturing and VCRReplies: 9Last Post: 6th Sep 2012, 00:05 -
What's a good capture card/device to capture VHS tapes?
By granturissimus in forum Capturing and VCRReplies: 15Last Post: 18th Jun 2012, 23:34
