Hello all,
I'm trying to digitise and archive VHS tapes using my Hauppauge WinTV-HVR-4000 on Windows 10. After reading some posts in the forum, I decided to capture AVI using huffyuv lossless compression and yuv2 for archiving. Then I could encode the video into DVD or H264 for general viewing etc.
The problem is that I can't get VirtualDub or Virtual VCR to capture the video. It's as if the applications don't recognise the card. I have tried a test capture using a trial version of a commercial software that seemed to work but was very limited in terms of the capture options and will not allow me to specify the codec so I know the card and the drivers are working perfectly.
Is there any other software that I can try?
Thanks in advance
Results 1 to 1 of 1
Tool to capture analog video+audio raw with Hauppauge HVR-1600 on Win7 PC?
By Razz in forum Newbie / General discussionsReplies: 1Last Post: 9th Jun 2015, 12:09 -
VHS Capture issue with Hauppage WinTV-HVR-2250
By Finkswitch in forum Capturing and VCRReplies: 37Last Post: 6th Jun 2013, 21:42 -
Can I capture from VHS to PC using my Hauppauge WinTV-HVR-2250?
By pantichd in forum Capturing and VCRReplies: 2Last Post: 4th Feb 2013, 19:27 -
Capturing Video from external source on a Hauppauge HVR-1800 card
By blueleo65 in forum Capturing and VCRReplies: 6Last Post: 14th May 2012, 18:54 -
Hauppauge WinTV HVR-1250 analog capture bug/glitch
By L-Train in forum Capturing and VCRReplies: 16Last Post: 20th Aug 2011, 18:42
