I am trying to convert a lot of 50fps dSLR footage to both lossless (Lagarith Lossless Codec) and edit-friendly lossy (x264vfw) files and maintaining the 50fps.
When I am looking at the footage in VirtualDub, the footage 'ends' halfway through. Opening up the same footage in Windows Media Player or Quicktime shows the full length clip.
What should I be doing?
	File information correctly shows that it is a 1080P video at 50fps.
	Apparently you've got a borked file — maybe a broken index, maybe two or more "sequences" that were joined improperly...
 VirtualDub can say much more than that. A MediaInfo report would be more complete, but not necessarily more helpful, if the source file is really broken.File information correctly shows that it is a 1080P video at 50fps.
 P.S.: try opening the problematic file through a DirectShowSource Avisynth script, and tell us what happens (or doesn't happen).Last edited by El Heggunte; 18th Jul 2016 at 07:29. Reason: add P.S.
	On the Open File dialog try using the Files Of Type pulldown to specify a different source plugin when you open the video in VirtualDub. Or use an AviSynth script to open the video.
  50fps footage for DVDBy kieranvyas in forum Authoring (DVD)Replies: 22Last Post: 12th Aug 2015, 20:35
  using avisynth to convert 50fps to 25fpsBy codemaster in forum Video ConversionReplies: 3Last Post: 15th Aug 2013, 18:11
  Avidemux 2.6 thinks my tv rec are 50fpsBy jamespoo in forum Video ConversionReplies: 8Last Post: 9th Jul 2013, 19:26
  Matrox AVI, 50fps and Adobe...?By dr_shabzzz in forum Video ConversionReplies: 1Last Post: 17th Sep 2011, 08:53
  Editing 50fps - best workflow?By Jeffboy in forum EditingReplies: 3Last Post: 30th Jul 2011, 11:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
