Dude, I'm hardly 'non-tech savvy'It's just been awhile since I've built a new PC!! But I think I am going to skip the RAID and just do regular backups to an HDD and/or NAS.
Yeah, I will... I have the Magician software from my SATA SSD.
I was running the same thing. 10% over=provision and RapidMode. Definitely made a difference.
I'm just sticking with Win7 right now myself.
Thanks!
Results 31 to 39 of 39
To date, the only thing ever that went wrong with the RAIDs I enabled on all those recent Intel chipset motherboards was one of the drives died and had to be replaced, then the volume was automatically rebuilt. In the meantime, user had full use of his computer. Or maybe Intel and all those wonderful mobo makers are doing it all wrong by making RAID standard, no? With the way it is on these boards, setting up RAID1 couldn't be simpler if I wanted to. Certainly beats me cursing when system drive decides to die in the middle of a PPro project with multiple vide and aud tracks
The Intel chipset RAID is nothing like the wretched, slow, and hard-to-manage s/w one on Windoze which people are wont to initially compare it to, until they try it for themselves.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
Imaging the SSD shortly after you have installed Windows 7 and your software, backing up the SSD at regular intervals, and keep important data somewhere else are all wise precautions, and even more crucial for SSDs than HDDs.
Everything I have read on the subject (from data center studies) indicates that although SSDs less likely to fail than HDDs during their rated life, they are far more prone data loss and corruption than HDDs.Last edited by usually_quiet; 20th Jul 2016 at 15:18. Reason: typo
I've been using Filesearchy lately, but it's good to have another recommendation to check out.
I just inquired about this in another thread, prompted by having read something online suggesting that the HDD --> SSD cloning might be problematical for certain reasons ? It would be a lot easier if this was not the case. I'm looking at replacing an HDD in an older laptop (Thinkpad T60). I'm aware that this option would be limited to SATA-1 speeds, but some reports indicate that this would still be worth doing, with a performance improvement. (The HDD in the laptop was a 5400 RPM model.) I happen to have a never used Samsung SSD here, but it is three years old or thereabouts. It was originally bought for experimentation purposes. I have read that reliability of the earlier SSD models may be suspect, with latter day models having improved in that respect. Also have some concerns re how much heat these things put out (particularly for this older model, if I try to use it), compared to conventional HDDs.When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form. -
I am interested in the options and ramifications of doing something similar. To that end, I'm curious as to just how much may be doable either via use of WINE or a Win-7 VM running inside of Linux. I know folks who have gone the latter route successfully, but they are not running a plethora of Windows video and audio manipulation programs. Somehow I doubt that running your basic business apps -- word proc, spreadsheet, browser -- is really comparable. So I'd like to hear from any of you who have tackled this challenge.
Another consideration is that emulation always extracts some overhead performance penalty, even where it works well. I would expect that is going to call for premium cpu horsepower and plenty of RAM.
Count me OUT for Win-10 also. That provides a lot of incentive to find a workable alternative. At the same time, surprising or not, I still see quite a few businesses out there that seem to be oblivious and continue running XP. If you have multiple computers, as many do these days, there is also the option of continuing to run a Win-7 editing rig that is walled off from the internet, or other security risks.When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form. -
Well, I will definitely make a disc image right after everything is up and running.
And do interval backups after.
Also, all my important stuff has always been backed up to multiple places... probably more than I need.
While I am simply installing Win7 now as I want to get this up and running... if you find out any good news about Linux/Win7 combo please let me know...
I may know a couple people myself that have some experience with that... if I find anything out I will post it. -
Hey lordhutt, I didn't realize you were the OP. I thought you were a drive-by user so I thought you were sarcastic. My bad.
Yes, it has to be cloned properly in a way where the OS won't treat the drive like an HDD anymore when transitioning is done. I used EaseUS to do this. You can't use the conventional cloning method where your SSD will basically be treated like a spinning disk drive.I just inquired about this in another thread, prompted by having read something online suggesting that the HDD --> SSD cloning might be problematical for certain reasons ?
My OS has been upgraded multiple times over the years since Windows ME. I have a lot of piled up programs installed and a huge registry hive and I haven't had problems since transitioning everything to a circa-2013 SSD. Older models may or may not be a problem, mine's a Samsung.
Also, does Filesearchy search the MFT or use the same craptastic method every other searcher did for the past 20 years?
SSD just got to another level!
By newpball in forum ComputerReplies: 14Last Post: 11th Jul 2015, 19:30 -
Smplayer - need advice on changing toolbar and menu language.
By Atotaloss in forum Newbie / General discussionsReplies: 2Last Post: 21st Feb 2015, 15:46 -
Anyone using an SSD with Linux?
By Moontrash in forum ComputerReplies: 7Last Post: 22nd Jan 2013, 12:33 -
New to SSD what do I need to do an buy?
By Denvers Dawgs in forum ComputerReplies: 10Last Post: 23rd Oct 2012, 19:10 -
SSD's...a few questions
By Moontrash in forum ComputerReplies: 1Last Post: 17th Dec 2011, 22:12
