    Jul 2016
    UK
    Hi, i'm having an issue with converting MPEG-2 .mpeg video into h.264 .mp4 with my video editor (Movavi).
    My issue is, the audio goes gradually out of sync in the h.264 mp4 video. The audio is fine in the mpeg video.
    The mpeg is interlaced 25FPS, the output mp4 is Progressive 25FPS.
    These are the specs of the MPEG-2 videos:
    Format                                   : MPEG-PS
    File size                                : 5.49 GiB
    Duration                                 : 2h 6mn
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 6 200 Kbps
    Writing library                          : ArcSoft MPEG-2 PAL
    Video
    Format                                   : MPEG Video
    Format version                           : Version 2
    Format profile                           : Main@Main
    Format settings, BVOP                    : Yes
    Format settings, Matrix                  : Custom
    Format settings, GOP                     : M=3, N=10
    Duration                                 : 2h 6mn
    Bit rate mode                            : Variable
    Bit rate                                 : 5 852 Kbps
    Maximum bit rate                         : 9 000 Kbps
    Width                                    : 720 pixels
    Height                                   : 576 pixels
    Display aspect ratio                     : 4:3
    Frame rate                               : 25.000 fps
    Standard                                 : PAL
    Scan type                                : Interlaced
    Scan order                               : Top Field First
    Bits/(Pixel*Frame)                       : 0.564
    Time code of first frame                 : 00:00:00:00
    Time code source                         : Group of pictures header
    Stream size                              : 5.18 GiB (94%)
    Source encoded stream size               : ArcSoft MPEG-2 PAL
    Color primaries                          : BT.601 PAL
    Transfer characteristics                 : BT.470 System B, BT.470 System G
    Matrix coefficients                      : BT.601
    Audio
    Format                                   : MPEG Audio
    Format version                           : Version 1
    Format profile                           : Layer 2
    Duration                                 : 2h 6mn
    Bit rate mode                            : Constant
    Bit rate                                 : 224 Kbps
    Sampling rate                            : 48.0 KHz
    Delay relative to video                  : 3ms
    Stream size                              : 203 MiB (4%)
    and this is a typical mp4 output converting from the above format:
    Format profile                           : Base Media
    Codec ID                                 : isom
    File size                                : 328 MiB
    Duration                                 : 25mn 55s
    Overall bit rate mode                    : Constant
    Overall bit rate                         : 1 772 Kbps
    Writing application                      : Lavf56.36.100
    Video
    Format profile                           : Main@L3.0
    Format settings, ReFrames                : 1 frame
    Format settings, GOP                     : M=1, N=25
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Duration                                 : 25mn 54s
    Duration_LastFrame                       : -19ms
    Bit rate                                 : 1 578 Kbps
    Width                                    : 640 pixels
    Height                                   : 480 pixels
    Frame rate mode                          : Constant
    Bits/(Pixel*Frame)                       : 0.205
    Stream size                              : 292 MiB (89%)
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Duration                                 : 25mn 55s
    Duration_LastFrame                       : -9ms
    Bit rate                                 : 192 Kbps
    Channel positions                        : Front: L R
    Stream size                              : 35.6 MiB (11%)
    Can anyone shed any light on what i'm doing wrong?
    Thanks,
    VSz
    Aug 2010
    San Francisco, California
    Does the audio get behind the video or ahead of the video? Is it originally a motion picture source?
    Jan 2007
    It may not be relevant, but is there a particular reason for reducing the resolution from 720*576 to 640*480?
    The source says it's 2hrs 6min
    The output says it's 25min 55 sec
    Are you sure this is the same video
    Somethings are really off
    Jul 2016
    UK
    The mpeg2 videos are vhs rips of home videos, so no motion picture score there haha.
    The resolution change is due to cropping, as the were a lot of black edges and fuzz to crop out, plus the aspect of the picture inside the black frames was 4:3 so 640*480 worked out best.
    No it's not the same output as input in the file data's, its just a typical output where the settings used are the same.
    I'm not sure if it behind or in front, I will have a look later and try and see. I will also do a like for like file data if that helps.
    Thanks for the replies.
    Jul 2016
    UK
    Ok so here are the like for like file data's.
    The audio is happening before the picture, so therefore the audio is behind the video, getting gradually worse as it goes on.
    MPEG-2
    General
    Format                                   : MPEG-PS
    Duration                                 : 2h 6mn
    Video
    Format                                   : MPEG Video
    Duration                                 : 2h 6mn
    Width                                    : 720 pixels
    Height                                   : 576 pixels
    Standard                                 : PAL
    Audio
    Format                                   : MPEG Audio
    Duration                                 : 2h 6mn
    Bit rate                                 : 224 Kbps
    MP4
    General
    Codec ID                                 : isom
    File size                                : 1.46 GiB
    Duration                                 : 1h 57mn
    Overall bit rate                         : 1 771 Kbps
    Video
    Codec ID                                 : avc1
    Duration                                 : 1h 57mn
    Duration_LastFrame                       : -30ms
    Width                                    : 640 pixels
    Height                                   : 480 pixels
    Stream size                              : 1.29 GiB (89%)
    Audio
    Format                                   : AAC
    Format profile                           : LC
    Codec ID                                 : 40
    Duration                                 : 1h 57mn
    Bit rate                                 : 192 Kbps
    Stream size                              : 162 MiB (11%)
    P.s. The running time is slightly different as i cut a bit of unneeded fuzz from the beginning and end of the recording.
    Any ideas?
    Thanks,
    VSz
    Jan 2007
    when did you cut the fuzz ? aka 9 minutes
    after completing the conversion or as part of the conversion process
    i think maybe you need to try a different editor program
    Jul 2016
    UK
    Cutting it makes no difference to the audio sync, it does it if i cut or don't cut.
    I cut it before conversion.
    Also the editor works fine for any other files, just not these interlaced MPEG-2 mpegs.
