To capture HD videos is the standard today, so what are you waiting for. Most of the camcorders price range between $600 to $1000 and up. These camcorders have all great quality and the big advantage is that they are already in digital domain. All the camcorders are easy it use, very user friendly. The overall zoom standard is 10x and 12x, there is camcorders with a higher zoom capability. The disadvantage with a camcorder zoom bigger than 12 xs is the video is vibrating; the human hand is not steady enough to keep the camcorder still so you will need a tripod. Some of the cameras come out with a stabilizer unit build in which helps.
The small HD camcorder doesn't always have the stabilizer unit build in. The cameras offer a similar storage devises like: MiniDV tape, DVD, hard-drive, and flash-memory card. There is camcorder that uses a variety of formats. This is so you can shoot long videos in one take. Not all the formats have big storage capability.
HD cameras have internal flash memory or flash memory card to store all the video and audio on. Flash memory or flash memory card is used by almost all cameras. Most of the HD camera manufactures have stopped to build cameras with DVD storage; you may still find this camcorder on the market. The DVD storage capability is 4.7 GB; the flash memory goes a lot higher like 16 GB 32 GB and more.
Flash-memory card models tend to be lighter and more compact than other types, although none have the viewfinders found on most other models
With the camcorders so small you can always have a HD camcorders with you for all your video memories and funny clips that happens all around you.
Is this helpful for you?
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 326Last Post: 2nd Sep 2025, 06:10 -
Sound difference with consumer camcorder and Prosumer camcorder
By kage123 in forum Newbie / General discussionsReplies: 5Last Post: 17th Apr 2014, 18:49 -
Buying advice on camcorder that can playback frame by frame slow motion
By idkwia in forum Portable VideoReplies: 1Last Post: 9th Jan 2014, 17:45 -
TBC buying guide?????
By yoda313 in forum RestorationReplies: 41Last Post: 11th Nov 2012, 09:03 -
Camcorder Buying Suggestions?
By jbartosh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 21st Oct 2012, 02:42
