Results 1 to 22 of 22
  1. Hi, I have been trying to capture video from my DirecTV mini genie on an HDMI video capture box called YK918H. I believe it is the same thing as the HDMI cloner box. well, everything seems to work fine but when I want to watch the file it doesn't work. I tried Avideux and it keeps saying something about a demuxer. Other video players can't detect the file time. please help.
    Use mediainfo(open video, view->text) and copy all the details and paste in this thread.
  3. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    Try playing it with MPC-HC (Media Player Classic Home Cinema).
    It that fails make sure it is not recording the encrypted HDMI signal?
    On my YK918H device i need to keep the recording button pressed for about 5~10 seconds to disable HDMI/HDCP protection.
  4. General
    Complete name : C:\Users\Owner\Documents\Desktop\Encode_1080P_10.m p4
    File size : 1.54 GiB
    this is all that shows up
  5. Originally Posted by The_Doman View Post
    still not playing.
  6. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    Originally Posted by hampshire178 View Post
    still not playing.
    Well..
    If possible try another HDMI recording source?
    What version of the capture/cloner box is it?, there are so many versions around.
    You could upload a (short) sample recording for us to analyse?
  7. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    Unfortunately , there is nothing in the file , no video/file structure, just only filled with zero's when opening with a (hex)editor ?.
    Possible try some other USB stick/device for recording?
  8. The_Doman is correct. The file is full of nothing but about 17 million zeros.
    Aug 2006
    As I recall from a thread last year, the HDML Cloner box came with equipped with firmware which allowed it to decode HDCP, but cracked firmware needed to be installed for the YK918H device to ignore HDCP.
  10. Originally Posted by usually_quiet View Post
    do you have that firmware
  11. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    We still not know what kind/version of YK918H clone box you have?
    The original cloner box or one of the many copied versions around?
  12. Originally Posted by The_Doman View Post
    its a copied version
    Aug 2006
    No, I don't and unfortunately when I went back to the thread mentioned above to check on the link to the hacked firmware that appeared in one of the posts, my security software issued a malware warning after I clicked on the link.
  14. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    Any link to the product page/ad of the capture box may be usefull?
    Because most copied cloner versions mention the HDCP defeat/decoding option.
    It still possible there still something else going wrong?
    Does the HDMI passtrough function of the box work properly?
    Is the incoming signal correctly detected (flashing green or blue )?
  15. Originally Posted by The_Doman View Post
    Here is where i got it from
    http://www.ebay.com/itm/YK918H-HDMI-HD-HDD-Video-Capture-Box-/171520719453?
    It passes through after i hold the record button for like 3 seconds and it does flash when recording.
  16. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    Here is a video of a someone posting firmware/recovery files for what seems to be the same device as yours?
    Youtube: YK918H Velocap HDMI Rec Unbrick step by step
    If indeed nothing else is working you sure can try to flash the included firmware?
    But possible the device could be faulty?
    It is worrying of course your recordings apparently are just empty with totally nothing in it??
  17. Originally Posted by The_Doman View Post
    it is still not working
  18. ok good news. I reformated my usb drive to FAT32 and now it works!
  19. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    Good to have it working then at last!
    Possible the USB device was in some incompatible format with the box, EXFat may be?
    It should work with FAT32 and NTFS.
    You have to find out if it splits the recordings in 2GB chunks when using NTFS or not.
    Latest clonerbox firmware versions should be able to record in one continuous file when using NTFS.
  20. i originally had it in NTFS
    Jan 2007
    i have the HDMI cloner box
    a 90 min 720P movie is just over 6GB one file, using my NFTS drives and sticks
    this discussion highlights the fact, there are Major differences, between the original cloner box firmware and the copies firmware
    and possibly low quality reject chips, being used in the copies
