    Jul 2001
    knoxville, tn
    I have been using this program (0.224) for a while to convert mkv files to mp4 and it has generally worked well. However the mp4 file will often have the audio out of sync by about 2.4 seconds. I can correct this by adding "2400" in the "Delay" setting. However lately I have had several mkv files that result in MP4Box crashing at 99%. The error in the log is "Mp4Box terminated with error: 3221226356"
    This is the source file information (from Mediainfo)
    eneral
    Unique ID                                : 102114455389470586777438309571762730193 (0x4CD2875B6F5D19211A555D703D5634D1)
    Complete name                            : K:\VIDEO\Race.mkv
    Format                                   : Matroska
    Format version                           : Version 4 / Version 2
    File size                                : 1.19 GiB
    Duration                                 : 1h 5mn
    Overall bit rate                         : 2 599 Kbps
    Writing application                      : Lavf56.25.101
    Writing library                          : Lavf56.25.101 / Lavf56.25.101
    Video
    Format profile                           : Main@L3.1
    Format settings, ReFrames                : 2 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 1h 5mn
    Bit rate mode                            : Constant
    Nominal bit rate                         : 2 500 Kbps
    Width                                    : 1 280 pixels
    Height                                   : 720 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 25.000 fps
    Bits/(Pixel*Frame)                       : 0.109
    Default                                  : No
    Forced                                   : No
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : A_AAC
    Duration                                 : 1h 5mn
    Channel positions                        : Front: L R
    Sampling rate                            : 44.1 KHz
    Frame rate                               : 43.066 fps (1024 spf)
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Menu
    00:00:00.000                             : :Chapter 1
    00:04:57.640                             : :Chapter 2
    00:50:26.480                             : :Chapter 3
    I pretty much have the default settings for MkvToMp4. The only thing I think I have changed is the output format (changed from m4v to mp4). This is the log output:
    Repack/encoder video to MP4 for Apple iPhone, iPad, ATV2. MkvToMp4 version 0.224 (x64)
    Build from: Sep 24 2013 14:57:05
    Use log file: ../Temp/Logs\10_07_2016_16_58_57.txt
    CoreAudioToolbox version: 7.9.7.9
    Added on list: K:/VIDEO/Race.mkv
    Started processing file: K:/VIDEO/Race.mkv
    Starting MkvExtract with the parameters:
    ../Tools/mkvextract\mkvextract tracks "K:/VIDEO/Race.mkv"  0:"../Temp/video.264"  1:"../Temp/Race_internal_audio_2.AAC"
    Extracting track 0 with the CodecID 'V_MPEG4/ISO/AVC' to the file '../Temp/video.264'. Container format: AVC/h.264 elementary stream
    Extracting track 1 with the CodecID 'A_AAC' to the file '../Temp/Race_internal_audio_2.AAC'. Container format: raw AAC file with ADTS headers
    Starting Eac3To with the parameters:
    ..\Tools\eac3to\eac3to  "C:\Users\shane\Desktop\MKV 2 MP4\MkvToMp4_0.224\Temp\Race_internal_audio_2.AAC" "..\Temp\Race_internal_audio_2_new.AAC" +2400ms  -progressnumbers
    AAC, 2.0 channels, 44.1kHz
    Applying AAC delay...
    A remaining delay of +9ms could not be fixed.
    Creating file "..\Temp\Race_internal_audio_2_new.AAC"...
    Done.
    Starting Mp4Box with the parameters:
    ../Tools/mp4box/x64/MP4Box.exe -new  -add "../Temp/video.264":fps=25.000:lang=eng:name="" -add "C:/Users/shane/Desktop/MKV 2 MP4/MkvToMp4_0.224/Temp/Race_internal_audio_2_new.AAC"#1:fps=25.000:lang=eng:name="" -itags tool="MkvToMp4 [www.mkvtomp4.ru] version 0.224 (x64)" "K:/VIDEO/test\Race.mp4" -tmp "../Temp/Mp4Box"
    AVC-H264 import - frame size 1280 x 720 at 25.000 FPS
    Total time: 41 sec.
    0 files processed.
    1 errors.
    Is there anything obvious here? Thanks.
    Jul 2001
    knoxville, tn
    The mp4box version included with 0.224 MkvToMp4 is 0.5.1-DEV-rev4765. I updated the files to the current version of mp4box which is 0.6.1-rev0=g72d766c-master and I still had the same error. When I used the command line with either of these, mp4box crashes at 99% when importing the video file, so the AAC file isn't hte problem.
    I had an old program called YAMB that also uses MP4Box and the version was 0.4.6-DEV (build 1). I took the .264 and .AAC files created in the TEMP directory by MkvToMp4 and used the command line for the older MP4Box and it works and creates and mp4 file. It does generate several:
    "WARNING: NAL Unit type 13 not handled - adding"
    The video plays fine with no audio sync issues, but playback is very choppy.
