i jus converted a divx file to mpeg1 format for a VCD
these are the programs/settings i used:
virtualdub - To convert audio (188KB/s total bandwidth required)
Sampling: 48000Hz High Quality
Precision: 16-bit
Channels: Stereo
tmpgenc - To convert divx to mpg
VCD (NTSCFilm)
Motion Search Precision: High Quality
in tmpgenc i put the avi file as the video source and the wav file as the audio source and started the conversion process, but when i viewed the resulting mpg file the audio was out of sync
i have looked around and guides to fix audio sync problems say to convert first using virtualdub, but i do this every time and this happens for some movies, for other movies it works
can anyone help me out with this problem? really bugging me...
any help is appreciated, thanks
Results 1 to 10 of 10
In VirtualDub, see under file information:
If it is 29.970 fps then load NTSC templete (in TMPGEnc)
If it is 23.970 fps then load NTSCFilm templete
See more here:
http://www.vcdhelp.com/divxtovcd.htm -
when u save the audio to wav wit virtualdub, maybe you should open the wav with winamp to uncompress the wav. or save the wav as PCM uncompress with virtualdub. I had the same problem with TMPGEnc, when I played them on my dvd it was out of sync, and insync. at times it went with the audio and sometimes it didnt.
I have just read in another topic today (AVI in sync, MPEG not) that you should bump up the priority of DirectShow filter (AVIapf) to 5, in TMPGEnc options...
It worked to the member that was having audio sync problems...
Fredİ -
when you say DirectShow filter do you mean DirectShow Multimedia File ReaderOriginally Posted by Fredİ
that is the only thing in the list that has DirectShow in its name...
File information in virturaldub is at, file then file information
Use the panasonic mpeg1 encoder, it won't make it out of sync -
these are the limitations that i would rather not want of the trial version of panasonic mpeg1 encoder:Originally Posted by Ryu_hoshi
4. The movie length for encoding is up to 30 seconds.
5. An expiration time function is implemented (1 month).
6. "Panasonic MPEG1 Encoder" will be printed on each frame of encoded movies.
7. Batch Processing is not available for Trial Version.
8. The MPEG1 system stream for VideoCD may not work with "Nero" CD-R writing software. -
lol oh yea, i forgot that i got it off this one website that had a serial but we are not allowed to post links to warez. I think you just need to uncompress the .wav file, when you save the wav in virtualdub, open the wav with winamp. stop it if it's playing, press CTL P, on the left where it says Plug in's, goto Output and double click on Nullsof disk writer plug in. Then choose a folder you want the uncompress wav, then click ok and close that window. Now click play and you will have an uncompress wav, after it's done you have to go back to Output and double click on Nullsoft Directsound so you can play music on winamp again. Now put the new wav file you created in the audio source in TMPG and choose your video source. Now when you encoded it, im sure it wont be out of sync. Because i had the same problem as yours once, that's when i switch to panasonic and it had a guide about converting the wav with winamp
[/quote]
[/quote]
yes, you are right...
Fredİ
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 12:51 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 10:05 -
audio not sync with virtualdub :(
By N3kr0 in forum EditingReplies: 0Last Post: 21st Jul 2007, 13:07 -
VirtualDub unable to keep audio sync'd on *source* audio
By falconne in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 07:12
