  1. Hello, I'm using a sotware called Evaer to record streaming videocalls, but I found that recordings in .mp4 with X.264 codec are not giving me the smoothest videos, is there an editor I could use to improve the quality of the codec to use with that sofware? Thanks so much
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Editing won't help. Capture ability is a byproduct of the machine specs and the codec used. Lower the resolution or try using a different codec.
    Google is your Friend
  3. Or the quality of your internet connection. If you use Wi-Fi use cable.
    Lowering the frame rate may also help.
