  1. I use RTMPDump to download a large number of videos with batch commands. When a download fails, the batch file continues with the next command and I'm left with an incomplete download. How can I force RTMPDump to automatically retry failed downloads? (Win7)
  2. use the --resume option
    Resume an incomplete RTMP download
    --resume
    or
    -e
    put that at the end of the command like this
    rtmpdump -r "rtmp://host/dir/file.flv" -o "filename.flv" --resume
    or
    rtmpdump -r "rtmp://host/dir/file.flv" -o "filename.flv" -e
    bering in mind you can't resume a live stream
  3. This doesn't retry files automatically.
  4. Originally Posted by hodrabostu View Post
    you can read all the rtmpdump parameters here
    https://rtmpdump.mplayerhq.hu/rtmpdump.1.html
    scroll down and you will see
    −−resume −e
    Resume an incomplete RTMP download.
    so wake up and be told
  5. I'm not sure you understand the question.
    Like I said, I'm using batch commands to download a large number of videos. Looks kinda like this:
    rtmpdump -r "rtmp://host/dir/file0001.flv" -o "file0001.flv"
    rtmpdump -r "rtmp://host/dir/file0002.flv" -o "file0002.flv"
    rtmpdump -r "rtmp://host/dir/file0003.flv" -o "file0003.flv"
    rtmpdump -r "rtmp://host/dir/file0004.flv" -o "file0004.flv"
    rtmpdump -r "rtmp://host/dir/file0738.flv" -o "file0738.flv"
    rtmpdump -r "rtmp://host/dir/file0739.flv" -o "file0739.flv"
    rtmpdump -r "rtmp://host/dir/file0740.flv" -o "file0740.flv"
    rtmpdump -r "rtmp://host/dir/file0741.flv" -o "file0741.flv"
    rtmpdump -r "rtmp://host/dir/file4092.flv" -o "file4092.flv"
    rtmpdump -r "rtmp://host/dir/file4094.flv" -o "file4094.flv"
    rtmpdump -r "rtmp://host/dir/file4095.flv" -o "file4095.flv"
    rtmpdump -r "rtmp://host/dir/file4096.flv" -o "file4096.flv"
    Now when the download of a file fails for whatever reason, I want RTMPDump to immediately repeat (or resume, I don't care) that download rather than jump to the next file. The -e instruction does not do this.
    I don't want to set the timeout higher since this is functionally different from restarting/resuming a download.
    What are my options?
  6. resume is the only option on rtmp files
    there is no other option
    also take note
    resume does not work on live rtmp streams
    −−live −v
    Specify that the media is a live stream. No resuming or seeking in live streams is possible
