My default search engine used to be Google, and was replaced by another - DEALWIFI.
They have uninstallation instructions. I run them but apparently they don't work and
that engine is still there. What must I do to eliminate this and to return to Google?
P.S. I also used Malwarebytes but it didn't solve.
				Results 1 to 25 of 25
	Try uninstall it in safe mode. And ignore uninstall instructions from them. And if you will have it in addons too remove it too.
	Restart press F8 and then choose -> windows safe mode. Uninstall as normal program. Control panels -> add remove software.
	Google is your friend:
 http://malware-detective.com/uninstall-mystart-dealwifi-com/
	Hech54 : I solved the problem with your suggestion.
 Bernix : I couldn't use your advise because the program didn't appear in Control Panel -> Uninstall Program
 Thanks very much Hech54 and Bernix.
	Mystart(dot)dealwifi(dot)com is a browser hijacker, so when you type in google.com you can get routed to dealwifi or some place else. It's a pretty common and have had it happen twice to me in the past decade. And Hech54 telling him to use google was shortsighted, considering it's pretty obvious he couldn't. Might have been better to list off a bunch of search engines, which dealwifi might not target, but we already know it targets google. Last edited by KarMa; 7th Jul 2016 at 19:52.
	Apparently both hech54 and Krispy Kritter were hired by Google, when Google was not evil...
	Try a different browser...and always disable java script unless you are on a trusted site.
 Even on videohelp I don't allow all the scripts to run..hey what is skimresources.com script on videohelp anyway??? 'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie 'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
	it helps pay for running the site. click through an ad, buy something and vhelp gets money. "http://skimresources.com/" --
	The second time in a few days I have a similar problem:
 My default search engine used to be Google, and was replaced by another - NUESEARCH.
 What must I do to eliminate this?
 I also have a program ADBLOCKER I don't know how it appeared. I uninstalled it ( Control Panel-> Uninstall Programs )
 but it appeared again few seconds afterwards. What can I do? My OS is Windows7. My Avast Free blocks this ADBLOCKER
 but it continues there.
	It may be time for something stronger....Look into ComboFix and ADWCleaner(both can be found here):
 http://www.bleepingcomputer.com/download/combofix/
 READ the instructions CAREFULLY.
	Finally, Hech54, I removed those threats from my PC ( I hope ). With ADWCleaner.
 Thanks again for your help.
	Jomapil,please do not open a new thread to a question you are already posted in an earlier thread,i moved that thread here,just continue here.. I think,therefore i am a hamster.
	I continue with other problems:
 When I open pages in Internet I'm invaded with undesirable adds.
 My Free Avast doesn't take any convenient actions. The programs
 Malwarebytes and AdwCleaner also doesn't do anything. What can
 I do to cancel and prevent these avalanche of adds?
 Thanks for your help.
	UBlock, or/and a custom hosts file.Originally Posted by Jomapil
 If you have K-Meleon, use F7 to enable Javascript only when strictly necessary.
	This thread brings back memories (in not a good way) when I used Windows as my primary OS and used to have to deal with this type of garbage. Now the only time I have to deal with it is if my mother's computer has a problem and even then I usually let me brother deal with it, I just don't the patience for this type of crap anymore.
	But, hech54, in that case ( Win XP Pro ), we can't run software that only works with Windows 7 isn't it?
	given that your first post was July 6th, get all your data off and reformat. 'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
  What software is used for that?By otto.normal in forum Blu-ray RippingReplies: 3Last Post: 18th Oct 2015, 10:42
  What software should I useBy damcz in forum EditingReplies: 5Last Post: 17th Jun 2014, 11:36
  Is There Such Software?By Reverser in forum Newbie / General discussionsReplies: 7Last Post: 12th Feb 2013, 13:31
  web server software to stream video to members - needgood software package!By tuprox in forum Video Streaming DownloadingReplies: 1Last Post: 26th Dec 2012, 22:34
  what Software to useBy whereswally007 in forum Video ConversionReplies: 2Last Post: 25th Oct 2011, 05:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
