MKV sucks hence I convert all either into avi or mp4 using Virtualdub or XMedia Recode.
But only the latter seems to be able to keep the subs in the output.
Virtualdubmod will not load mkv files at all containing subs ("only handle [S-TEXT] subs for the moment").
Extractors I found here so far - they either do not work, will keep you days for ocr checks
or leave rubbish which none of others programs like Subtitle Workshop can deal with.
Is there a plugin like texsub but the other way round and ideal where I may set style
and position too?
And if not - is there a more clever extractor for subs similar to Omnipage which does not force an
affirmation for each line i.e. where you can save all and uncorrected straight into a txt file for
spell checking with other editors like Word or else?
Drop the mkv onto Subtitle Edit.they either do not work, will keep you days for ocr checks
cheers videobruger,
you made my day!
Now I'd like to strangle Google for giving me thousands of results in the first place but not that one... -
converting mkv or avi to mpeg2 - hardcoded subs not visible
By rogmath in forum SubtitleReplies: 2Last Post: 2nd Nov 2013, 17:01 -
Trying to demux MKV file and remux as AVI with hardcode subs
By medicated in forum Video ConversionReplies: 24Last Post: 2nd Aug 2013, 21:48 -
mkv to avi with original subs
By tekkai in forum Video ConversionReplies: 6Last Post: 28th Jan 2012, 03:21 -
Adding subs to avi in virtualdub with textsub
By djgazzabhoy in forum Video ConversionReplies: 3Last Post: 26th Nov 2011, 06:04 -
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 03:20
