I purchased one of the first dvd burners back in the 90's. I converted all my VHS tapes to Dvd Neg R format.that player has since died.
now i have all my home movies on dvd neg r disc and can't play them. my player only sees audio files on the disc.
Anyone have suggestions? please feel free to email me as well.. jeffpankey@hotmail.com
Is it a player or a disc problem? Player would be easy, try a different one. Disc, not so easy.
I would closely inspect the discs and see if any obvious physical problems are visible.
I also would guess that the files are in regular DVD video form, VOBs, IFOs, BUPs? DVD - (minus) is just the disc type. We aren't talking Divx or similar?
The brand of disc makes a big difference also. Some cheaper brands didn't last too long, even with careful storage.
The audio in a DVD format is part of the video VOB files, so if it plays, the other should. The audio folder is empty.
You might try an extraction program like IsoPuzzle to see if the rest of the files are recoverable.
And MediaInfo should give you info about the contents of the discs.
More information about the discs would help and others here may have more ideas.
And welcome to our forums.
What brand media did you use?
Are your discs "finalized"? (can check using ISOBuster, etc)
I ask, because assuming you used quality burning media, those (finalized) discs should be playable everywhere.
Clarify for us also please whether you burned these discs using a settop DVD recorder or a PC-based capture-encode-burn equivalent. The former should, with proper usage, create perfectly valid & common DVD-Video structure; the latter may also but can be all over the map if you don't know what you're doing.
Regardless, I would hope that you didn't throw out your VHS home movie originals.
Help with format problems
By greeneyedcajun in forum DVD RippingReplies: 1Last Post: 23rd Dec 2015, 01:01 -
Video format problems after muxing
By milkyway50 in forum Video ConversionReplies: 12Last Post: 4th May 2014, 22:02 -
.MOV format problems.
By thanosda in forum EditingReplies: 10Last Post: 27th Dec 2012, 16:17 -
Problems with Format Factory
By wurm7467 in forum Video ConversionReplies: 5Last Post: 15th Sep 2012, 09:54 -
Problems after converting mkv to blu-ray format
By BigGreenie in forum Video ConversionReplies: 17Last Post: 7th Jan 2012, 06:27
