Im working on converting my first original video into DVD format with TMPGenc and the "Link to Avisynth" plugin for Premiere. Im currently encoding only the video, as I want to play around with encoding the audio into 6-channel surround AC3 with a couple programs I have to do that, including SmartCode. Since I can do the audio separately, is this a good way to do it? Even if I just wanted regular 2-channel digital AC3, would the quality be better in a stand-alone program rather than in TMPGenc? I would assume so
It's better to fix the sound outside TMPG, then mux them together in bbMPEG..
- Twin - -
6 channel AC3 is not accepted by most consumer level DVD authoring programs, though I believe spruceup will accept audio in any valid DVD format. So unless you know for definate that you can author your DVD with this kind of audio you are wasting your time. If you can, let the DVD authoring program do the multiplexing, no need to multiplex into a single stream beforehand. Good luck all the same.
Convert AVI to ? to TMPGEnc DVDAuthor with 5.1 audio
By NDMMackay in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 08:02 -
Puting a slide show and a video separately onto the same DVD
By coastie in forum Authoring (DVD)Replies: 3Last Post: 10th Sep 2011, 05:44 -
Edit Left OR Right Separately >> AVS4YOU Audio Editor
By mrlewp in forum AudioReplies: 0Last Post: 12th Jan 2011, 22:34 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 22:52 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 18:11
