Thread: TMPGENC Authoring Works 5 VBR or CBR
  1. #1
    Hello to all! When working in terms of video quality with tmpgenc authoring works 5 what is best to use 1 or 2 pass VBR or CBR? What would give me the best video quality because I'm a newbie to all of this. I would appreciate it Thanks
    Member
    Aug 2003
    Posts
    18,919
    Re: TMPGENC Authoring Works 5 VBR or CBR
    In almost all cases you'll want to encode for VBR.
    Ok so wil it be better to do one pass or two pass?
    Two-pass
    but then again. IMO things arn't that rigid. If your playtime is about an hour with max bitrate it doesn't really matter. You could use CBR for that matter. Also if your source is something highly compressibil like cartons you might not see any difference. And 1-pass is faster since you previously complaint about encoding time.
    Ok friends a little update I used 2 pass but it takes 9 hours to do it. What's a good laptop with fast processors I could buy that won't break the bank I'm looking for preferably HP
  1. TMPGEnc Authoring Works 5 Problem
    By Mart7 in forum Newbie / General discussions
    Last Post: 15th Aug 2015, 12:45
  2. Help with Tmpgenc authoring works 5
    By littlebase22 in forum Authoring (Blu-ray)
    Last Post: 16th May 2015, 00:44
  3. Need a alternative to TMPGenc Authoring Works
    By nitrocell in forum Video Conversion
    Last Post: 19th Dec 2011, 14:53
  4. My TMPGEnc Authoring Works 4 in window 7
    By sleung in forum Authoring (DVD)
    Last Post: 12th Sep 2011, 17:07
  5. My TMPGEnc Authoring Works 4 in window 7
    By sleung in forum Newbie / General discussions
    Last Post: 11th Sep 2011, 19:54
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
