Results 1 to 11 of 11
  1. are there free video editors that are somewhat on par with adobe premiere pro/ vegas pro in terms of features and functionality, and uses x264 when rendering?
  2. Lightworks, Edius, Da Vinci Resolve, Catalyst and in a class of its own (for good and bad) Avid.
    But the two you mentioned first are the most popular, and deservedly so.
  3. Aviutl also, tones of community-made effects but may be difficult to learn at first.
    Export format can be almost anything (H264,H265, BMP sequence...).
    Stopping development until someone save me from poverty or get me out of Hong Kong...
    Twitter @MaverickTse
  4. I meant actual the actual x264, not the commercial h.264 encoder. Aviutl seems to use it, the four mentioned by smrpix, I will check. Thanks, any more will be appreciated.
  5. Originally Posted by nixiejames View Post
    man... the jargon problem again...
    H264, H265 are video stream "format" or "codec"
    x264 and x265 are "encoder"
  6. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    H264 and H265 are standards, which I guess can also be called formats but idk. Standards which many codecs can be built to conform to, like x264 and x265. x264 and x265 are considered codecs, as codec stands for encoder/decoder. Even though x264 and x265 don't decode, and rely on standard decoders.
    https://en.wikipedia.org/wiki/Video_codec
  7. correct me if i'm wrong but i thought that x264 is a free and open source encoder which produces the h264 codec.
    hence, i believe that commercial products like blurays and software like adobe's have a different encoder which produces the same codec. i just personally call that encoder "h264 encoder".
    am i totally wrong?
  8. x264 is a free encoder that produce video data compliance to the H264 format standard.
    "H264/AVC encoders" include all encoders that can produce valid H264-compliance video data
  9. besides Aviutl,
    -Adobe premiere suppose to have some third party expensive plugin that exports H.264 using x264 encoder
    -there is also x254vfw for Premiere and Vegas that exports AVI container with H.264 in it using x264 encoder - not sure if that is the way to go
    -There is DebugMode Frame server plugin for Premiere and Vegas that serves timeline into following application of your choice (that accepts vfw avi) , which could be for example Avisynth following x254 encoder as well. This needs some setup first to make things work.
  10. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    am i totally wrong?
    H264 is not a codec but a standard, a standard which codecs follow to produce compatible video. Adobe uses a codec, probably a proprietary one, to produce H264 compatible video.
  11. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    And "Kodak" is not actually a codec either.
