I successfully demuxed, edited the audio stream then remuxed an MKV file, using AVIdemux. But none of my video converters will recognize the file that MediaInfo reports to be encoded with HEVC (High Efficiency Video Encoding), CBR 3000 kbps, 25 fps. The codec ID is V_MPEGH/ISOHEVC. Media Player Classic plays the file OK on my PC. I tried converting the file to a DVD compilation (VOB, IFO, BUP), using ConvertXtoDVD (v5) and AVS Video Converter and the finicky AVStoDVD, but none support the file.
XMediaRecode is able to convert the file to AVI that ConvertX will recognize, but in doing so the loss of video quality is unacceptable to me. Is there an converter that can burn the movie to DVD disc, supporting an HEVC encoded file?
				Results 1 to 17 of 17
	Djard
 medfaith@yahoo.com
	DVD is not HEVC , and HEVC is not yet widely supported
 All DVD converters will convert to MPEG 2 for DVD
 Your best option is to covert / transcode the file to something like h264 encoding
 Inside an mp4 wrapper
 Avidemux can do this for you, so can several other programs
 Before trying to author a DVDLast edited by theewizard; 4th Jul 2016 at 01:17.
	Why not convert to dvd mpeg2 with xmedia recode?
 But you will always lose video quality by reconverting it. Especially if it's in HD quality.
	I converted the file to AVI and also to MP4 (using H.264) with XMediaRecode at the same bitrate then compared the two. The AVI copy was pixilated in action scenes. The MP4 file was much better and acceptable. Thanks for your kind response. I visited VSO's site and read that they are working on a H.265 for ConvertX. Djard
 medfaith@yahoo.com
	Did you check the output resolution and try raising the bitrate?
 Just for fun I tried converting an animated short film in an MKV container from 1920x824 HEVC with AAC audio to DVD-compatible MPEG-2 and AC3 audio using the DVD Player (Standalone) and DVD Player (VOB) presets. The video was very blocky. I found XMediaRecode uses a very low resolution by default (352x288 PAL quarter D1) rather than full D1 (NTSC 720x480 or PAL 720x576).
 After setting the encoding parameters in the Audo and Video tabs, I went to the Filter/Preview Tab and set the following:
 Video Size: 720x480
 Scaling Mode: Bilinear
 Dithering Algorithm: Auto
 Aspect Ratio: 16:9
 Zoom: Letterbox
 The conversion was decent looking, but there were a number of P-STD buffer underflow errors near the end of the movie during authoring with Muxman. I then tried IFOEdit for authoring since it is very permissive, and got a playable DVD in spite of similar errors.
	Yes, I did set the bitrate and resolution to the source file.
 You got IFOEdit to work? Wow! After many hours of following nebulous guides and trying various options, I gave up on it, thinking it was a failed project. What can I offer you for the steps you used to make this app work?Djard
 medfaith@yahoo.com
	I have been using IFOEdit to create menuless DVDs for somewhere around 10 years. It isn't that hard.
 Create a DVD compliant VOB with MPEG-2 video and AC3 audio using XMedia Recode or some other program.
 Open that VOB in VOBEdit and demultiplex it into a m2v file and an AC3 file.
 Open IFOEdit and click on "DVD Author" in the menu bar. The "DVD Author/Multiplex Dialog window appears.
 Click the button next to the "Video" input box and import the m2v file.
 Click the button next to the "Audio" input box and import the ac3 file. Enter a delay in milliseconds if you have one, Select the language from the drop down list under the delay box.
 If there are .sup subtitles available, click the button next to the "Subpicture" box and import the sup files.
 Click the button beside the Destination box and choose a folder to hold the authored video.
 Click OK and wait.
 I haven't added chapters in a long time. I used Cuttermaran to generate them.
	Thank you for the steps regarding use of IFO Edit and also the info about recoding HEVC encoded video: I was under the impression that increasing bitrate would not improve video quality, but then I was not considering HEVC. Building a website from scratch seems a breeze compared to video editing...complex stuff. Again, thank you sooooo much. Djard
 medfaith@yahoo.com
	You can not improve a poor source by simply increasing bit rate and recoding
 But when transcoding aka changing encoding format ,
 To maintain quality of the source in the new format you must use the corresponding bit rate needed by the chosen codec in your case avi xvid
 HEVC to xvid/dvx increase bit rate
	There you are attacking me again, you are nothing if not redundant and predictable
 He said he set the bit rate and resolution the same as source when encoding to the dvx file and was disappointed at the low quality
 He did not compensate for the difference in compression rates and the need for a higher bit rate when using dvx codec
 He responded that he thought increasing bit rate would not improve quality
 I merely clarified the point, that source can not be improved, but the right bit rate is needed when transcoding to maintain the available qualityLast edited by theewizard; 8th Jul 2016 at 13:31.
	Sorry to be such a poor student, but do I understand correctly that while video quality cannot be improved by increasing the video bitrate, some increase is required when recoding H.265 to H.264, such as "2-3 times," for parity?
 For example, to convert a stream encoded with HEVC at 3000 Kbps in an MKV container to H.264 in MP4, I would need to increase the bitrate to, say, 9000 Kbps? Of course I would retain all the other parameters, such as resolution, etc. The H.264 in a MP4 container is supported by ConvertXtoDVD.Djard
 medfaith@yahoo.com
	i don't know the exact number, but i think HEVC to H264 is more like 1.5 times
 i dont think 3 times is needed
 going to Xvid would need 3 to 4 times bitrate increase
 somebody with more experience comparing HEVC to H264 will possibly post a more accurate figure
	Frequently it isn't possible to give an exact answer to the question of what bit rate to use for a given conversion. It is almost always a judgement call made on the basis of previous experience and a subjective, personal evaluation of quality in the converted file. Going from HEVC to H.264 might require 1.5 time the bit rate or twice the bit rate, depending on the source and the encoding options used.
 Encoders cannot distinguish compression artifacts and noise from detail and movement. This means converting a noisy, bit rate-starved, artifact-ridden version of a video requires a using higher bit rate to remain close to the original quality than converting a pristine version of the same video would.
 DVD and Blu-ray have an official spec defining the upper limit on allowed bit rates as well as constraints on size placed on them by the optical media that needs to be used. Having a spec makes it easier to figure out what bit rate to use because so many of your choices are controlled by the spec.
	That helps and makes sense. Thank you very much. Djard
 medfaith@yahoo.com
  H265/HEVC encoder which supports alpha channel?By Gyan in forum Video ConversionReplies: 5Last Post: 10th Jul 2015, 14:15
  Divx HEVC encoder now supports 4k encodingBy deadrats in forum Video ConversionReplies: 8Last Post: 14th Aug 2014, 01:23
  AviUtl 1.5 now supports HEVCBy racer-x in forum EditingReplies: 1Last Post: 22nd Feb 2014, 20:45
  SKYFALL (James Bond series) was the first Hevc encoded movie in torrent?By Stears555 in forum Video ConversionReplies: 14Last Post: 14th Nov 2013, 09:18
  Anyone tried A's Video Converter ? (supports: AMD APP, AMD VCE, QSV)By Selur in forum Video ConversionReplies: 1Last Post: 11th Feb 2013, 03:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
