It's closer, the levels, the fps and framecount are correct, but a few frames are misorded. Recall above I mentioned some l-smash versions have problems with fraps. You're probably using one of them. Some ffms2 version do too, but I would try another ffms2 version
download ffmpegsource2, you'll need LoadPlugin("PATH\ffms2.dll") if it's not already in your system avisynth/plugins directory
Instead of LWLibavVideoSource, use FFVideoSource
FFVideoSource("C:\Users\Admin\Desktop\swtor 2012-12-25 20-46-52-81 7 sec.avi")
AVISource will work for sure using the fraps decoder, but it will return RGB and you will unnecessarily get quality loss if you encode a YUV version
But I would still try to fix the source and recording issues first
Results 31 to 34 of 34
Yeah, i it her too many times..
Now i'm using OBS, so i don't have that problem..
Also problem with fps solved (https://yadi.sk/i/mMdBqH7kt2hxJ), thanks for it and your helping
Does this forum have something like
"Best answer" or other thing of appreciating?Last edited by Dante4; 5th Jul 2016 at 17:16.
Basic question about scenario Converter > VirtualDub > Converter
By XenonS in forum Video ConversionReplies: 12Last Post: 14th Oct 2015, 09:32 -
Conversion settings for Wondershare Converter; export settings for Pinnacle
By avz10 in forum Video ConversionReplies: 1Last Post: 19th Jul 2014, 12:41 -
Wondershare Video Converter Ultimate vs WonderFox HD Video Converter Factor
By zzzk in forum Video ConversionReplies: 1Last Post: 3rd Jan 2014, 17:25 -
Any Video Converter - which settings to use ?
By elubitsch in forum Newbie / General discussionsReplies: 11Last Post: 30th Dec 2012, 07:41 -
x264: are ME settings conflictory to SUBME settings?
By deadrats in forum Video ConversionReplies: 1Last Post: 13th Dec 2012, 18:54
