If I try to eject a disc I hear a whirring sound and have to literally thump the top of the player in order for it to open. I opened the player yesterday and it seems that the disc clamp is magnetic and sticks to the laser assembly when it raises. The only way to eject a disc is for me to push up on the disc clamp in order to allow the tray to move.
I've put a short video on YouTube to show what I mean.
https://youtu.be/Lu5PhfamthI
Anyone know how I can fix this? Thanks!
Results 1 to 11 of 11
Probably the load belt is slipping and doesn't have enough grip to overcome the magnet. Try cleaning or replacing the belt.
Is that the one under the disc tray? It looks a little loose!
Any idea where I could buy a new one from?
Many thanks! -
Yes, that's the one. One trick you can try is to put the belt in boiling water for 15 minutes or until it's shrunk enough to work again. Otherwise, the most economical replacement will be an O-ring from the hardware store. Try to get one the same size or slightly smaller.
Sharing my LG DVR stuck tray. The tray bottom was scratching the front penal. I took out the DVD drive and put tape on the chasis at the 2 front screw holes. Just enough to raise tray clear of the front housing.
I tried the boiling water trick but no dice; the belt is still visibly loose.
Can anyone recommend a website to buy belts? -
Google "square drive belts." Phillips does not provide a replacement part, so you will need to measure and match your belt.
I've used a small rubber band to replace the belt and it worked.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
The problem with an ordinary rubber band is that it won't last more than a few months. An O-ring from the plumbing section of the hardware store is relatively cheap and will last a lot longer.
DVD Tray Opens Only With Disc In Tray
By CobraPilot in forum ComputerReplies: 4Last Post: 17th Feb 2016, 02:58 -
Hard drive in Philips DVDR3455h/37 crashed, stuck on "LOAD"
By jkozura in forum DVD & Blu-ray RecordersReplies: 5Last Post: 6th Jul 2015, 18:27 -
Tray Error on samsung dvd-E360
By gabotronia in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th Apr 2015, 14:15 -
Panasonic dvd recorder tray stuck
By suebe in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2013, 04:04 -
Panasonic S97 tray will not open
By southland66 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Nov 2011, 02:24
