Example i got 45GB movie i want to add subtitles .
Subtitles synchro is very bad so i need multiple editing testing checking times when to cut when to move forward ...
For such thing i need bout 10 time authoring = 450GB to write.
They are tellin SSD disk need 2PB to be killed
So 2 movies = bout 1TB
So is there any point to use SSD for Blu Ray authoring not only for subtitle but also for audio? Or forget? Some1 from you are using maybe SSD for authoring? or better way is to move to UBS 3.0? 90mb/s speed write.
Just use Subtitle Edit, which lets see and edit the subtitle sync in realtime. No need to author 10 times. And when you are done, it can export in .sup, .srt, .sub/.idx, or any other format you need.
Authoring and menus in MultiAVCHD, or is there a better way?
By MrPastry81 in forum Authoring (Blu-ray)Replies: 1Last Post: 20th May 2016, 03:10 -
.TS files jumping after authoring with MultiAVCHD/TSMUXER
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 8Last Post: 24th Jun 2015, 18:57 -
Problem authoring .m4v file using TSMuxer/MultiavcHD
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Sep 2013, 08:02 -
New to SSD what do I need to do an buy?
By Denvers Dawgs in forum ComputerReplies: 10Last Post: 23rd Oct 2012, 18:10 -
SSD's...a few questions
By Moontrash in forum ComputerReplies: 1Last Post: 17th Dec 2011, 21:12
