Hi there, I'm trying to improve a bit the contents from a game's DVD-Video that were badly exported. I know I can't fix the ghosting (Probably because it was converted from NTSC to PAL), but I'm trying to figure out if I can fix the bad resizing issues.
Here's a movie sample and a couple of screenshots. Keep in mind that the original footage is a PlayStation 2 capture and therefore, already aliased.
https://mega.nz/#!4UlmBDYb!CW52V22DZfYw5WonIFJwVNJrMeSLAKagKCYgTXoA8gM
Thank you.
Results 1 to 1 of 1
undo audio codec in Axis Security Cam file
By lsixecho in forum AudioReplies: 1Last Post: 22nd Jun 2016, 19:02 -
Scale to SD and then encode, or scale during encode?
By katieburchett in forum Authoring (DVD)Replies: 4Last Post: 27th Aug 2015, 18:35 -
Will firmware update undo region code hack?
By keepingup6 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 2nd Jun 2015, 04:39 -
Can you undo in software sephia color in video
By mammo1789 in forum RestorationReplies: 14Last Post: 6th Jun 2013, 09:44 -
Scale up a video?
By CrazyMLC in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2012, 00:30
