I want to convert a video I recorded to 720x4??. But I'm wondering what resolution I should record in: 1920x1080 or 1280x720.
Does one provide better quality if I downscale to 720x4?? assuming the end file size will be the same.
Results 1 to 9 of 9
What are you recording and with what?
It's usually best to have the highest resolution possible first and then downscale from that. -
Do you mean you've recorded it on a DVR and are going to play it back and capture it on your computer? Best would probably be the same as the resolution it's recorded in the DVR. If it's 1080i you'll need to deinterlace or IVTC and that makes it a little harder.
Did you really mean 720x4 (four pixels in height) ? Just curious why / what scenario ?
Yes, I'm recording from an Elgato HD60 Pro. I believe you have an Elgato as well? I tried recording in the Elgato capture software and compared it to some other rips people have made.. my videos seems to lack details (raw recording) and has a bit of blur. Do you think using OBS Studio will be better quality?
Definitely capture in the highest res possible before downscaling.
As for what pixel height for 720p wide, if the video is 16:9 then 720/(16/9) ~= 404.
But one of the best bits of advice I ever read is that you should downsize to dimensions that are mod 16, ie. evenly divisible by 16.Video encoding and decoding is basically matrix processing and doing this makes the video encode and decode better. So I actually use 720x400 for this sort of thing. Sometimes the encoder presets handle this eg.in Handbrake.
Help up-scaling anime
By zanzar in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2015, 01:30 -
Combining clips of different resolutions without scaling?
By Gameshow Host in forum EditingReplies: 13Last Post: 21st Dec 2015, 12:14 -
PotPlayer subtitle scaling
By Hahahhaha in forum Software PlayingReplies: 10Last Post: 15th May 2014, 10:16 -
scaling question
By hoodleehoo in forum Newbie / General discussionsReplies: 1Last Post: 27th Aug 2013, 06:29 -
KMPlayer and bicubic scaling
By Asterra in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 04:10
