I'm wondering if it's possible to edit idx/sub subtitles.
I've found a few annoying errors in some TV shows. For instance, the use of the term "tyres screeching..."
I don't know who created the subtitles, but they did a very good job for the most part, only some minor spelling errors like the one shown above (tyres should be tires)
I like the format they are in, idx/sub because the subs change location depending on speaker/other info on the screen.
srt files tend to overlap credits at the beginning of movies as well as fonts, italics, bold and other formatting.
So, the question being, is it possible to edit the subtitles in some way without converting to srt with OCR and dealing with all those errors.
Example: convert to another, less annoying format, then edit, then convert back to idx/sub
Thanx in advance...
You would have to extract the subtitles to image files (as that's what they really are, idx/sub stores bitmaps, not text) and edit them in an image editing software and then make a new set of idx/sub from that.
The editing part can be a good deal of tedious work and you would need to find out the original font, outline, spacing, etc. for it to look like it's original. -
"Tyre" is generally the spelling used in British English, I believe. This article may explain it better: http://grammarist.com/spelling/tire-tyre/
If cameras add ten pounds, why would people want to eat them? -
Being from Canada, I didn't know there was a difference in spelling and I can learn to accept that.
I'll have to keep it in mind that some words have different spelling in different parts of the world.
Thanx for the info.
edit and save idx/sub (vobsub) files
By KamikazeBE in forum SubtitleReplies: 5Last Post: 4th Nov 2014, 03:40 -
How to convert 3D idx/sub subtitles to 2D
By rhaz in forum SubtitleReplies: 14Last Post: 27th Dec 2013, 08:06 -
Question how to edit sub/idx file
By jimdagys in forum SubtitleReplies: 6Last Post: 29th Jan 2013, 15:07 -
Is possible to use idx/sub subtitles in DVD without convert them?
By mygh in forum SubtitleReplies: 1Last Post: 12th Sep 2012, 02:41 -
How to edit .sub/.idx ?
By Mokuton in forum SubtitleReplies: 3Last Post: 24th Jul 2011, 12:44
