Basically, wanting to burn an entire show to 2 or 3 discs (Because sadly it's not something that can be bought) and I'm just wondering the best way to go about it.
I've gotten myself a burner, will be getting the discs next. Far as I can tell, BDXLs aren't a smart choice due to compatibility, so figuring I'll get a few regular BDRs.
So it's just the burning itself I want to get right. Considering how expensive the discs are, the less muck-ups I make, the better!
Been looking into multiAVCHD, although it doesn't seem to be particularly user friendly. Far as I can tell it supports the files I have at least and I already have all the codecs it requires.
But figured I'd ask just in case, if there was something easier or better. Heck, even a step by step guide. It's a more specific request than guides I've seen, simply because of the subtitles in the MKVs themselves.
If anyone could help me, please do!![]()
Results 1 to 14 of 14
I think the free bdrebuilder can do that also. Under File->Import->Video Files and add all your mkvs. But I'm not sure about the subtitle support.
Hmm, I'll look into that one too. Thank you.
Shame that nothing seems to be particularly idiot-proof though. :P -
I tried bdrebuilder and it re-encodes compliant mkv(1280x720) which multiavchd doesn't do,if you just read some of the help files on multiavchd it can make great menus that are stills or moving.
^jdobbs says that you can let BD Rebuilder import the MKV's and set up the pseudo-Blu ray structure and use it if you are certain that the video and audio are already compliant to Blu-ray specs.
Just don't start the encoding process.
Didn't work for me because the video and audio went out of sync, but apparently that is a very, very rare event. -
No, BD Rebuilder will make a crude menu for you if you import more than one MKV, so there is no real need to use multiAVCHD afterwards. But I don't think BD Rebuilder will handle subtitles in MKV files well.
Multiavchd handles subtitles with customization and no need to use bd rebuilder either.
Well, just finally finished building/burning the first of the two BDrs I set out to make with multiAVCHD.
Video and audio have turned out very well, menus too. Even got a song playing in the background, very nice.
Just having a slight issue with subtitles. Whenever there's a sign or something else subtitled, for instance, and someone speaking is subtitled, only one will display. Or the latter will be displayed later, out of context. Do BDs support multiple subtitles on-screen at once or not?
Also, it doesn't like accented characters. Is there anything I can do about either of those things?
changing embedded subtitles timing
By aruwin in forum SubtitleReplies: 3Last Post: 8th Sep 2014, 01:56 -
How do I extract subtitles from several mkvs?
By piknockyou in forum SubtitleReplies: 0Last Post: 3rd Jul 2014, 05:34 -
Ignore the default embedded subtitles
By beycan in forum SubtitleReplies: 2Last Post: 28th Nov 2013, 22:19 -
extracting/cropping big MKV with embedded srts to smaller mkvs
By tokadi in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2013, 07:14 -
Question about which editor I should use for a specific task.
By DoctorDyna in forum EditingReplies: 6Last Post: 1st Feb 2012, 12:34
