Hi,
So I have this software for a long time now and I'm ok with it, but I have some problems while changing the FPS value.
if I try to change the fps, it reset the Num/Show tabs to the value of zeros(00:00:00:000), so I can't properly synchronize the subtitles.
I remember fixing that before but can't remember how...something with "vobsub" or ffdshow.
I need to fix it because of some time delay due to the wrong fps.
ok now with this one I have a different problem
After I sync the subtitles from one line forward it works fine for some lines after that but then with every few lines the delay grows more and more... at the Subtitle Workshop I had the same problem and i thought its an fps problem but here I entered the right fps and yet there is a delay...
Problem with Subtitle Workshop 6.0b: buttons disappearing
By Patapin in forum SubtitleReplies: 2Last Post: 28th Nov 2014, 04:13 -
Subtitle Workshop (SW) problem
By suadnovic in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2013, 11:24 -
Problem displaying movies in Subtitle Workshop
By Kahlua02 in forum Software PlayingReplies: 6Last Post: 19th Aug 2013, 10:46 -
By btouburg in forum SubtitleReplies: 3Last Post: 11th Mar 2013, 20:33 -
Subtitle workshop, rewinding problem
By ~Fly in forum SubtitleReplies: 5Last Post: 13th Mar 2012, 13:36
