I'm using this below MeGui command line to convert my vido files to h264 mp4:
program --level 4.1 --bluray-compat --preset veryslow --tune film --pass 2 --bitrate 6000 --stats ".stats" --open-gop --b-adapt 1 --ref 4 --slices 4 --vbv-bufsize 14000 --vbv-maxrate 14000 --subme 9 --no-fast-pskip --tff --colorprim bt709 --transfer bt709 --colormatrix bt709 --pulldown 32 --min-keyint 25 --sar 1:1 --output "output" "input"
But I'm having problems in making the GOP settings to work & coz of that I'm having trouble in seeking/skipping the converted video file. So i would really appreciate if someone could give me the FFMPEG version of the above command line of MeGui, coz I'm quite baffled with FFmpeg's script. Please help.
Example bellow (you need to modify and maybe add few things if you insist to use some settings):
Not sure about your settings, crf is better than 2 pass, keyint_min=25 for ?Code:@SET x264opts="crf=20:vbv_maxrate=62500:vbv_bufsize=62500:level=4.1:keyint=250:cabac=1:threads=auto:sliced_threads=0:slices=-1:no_psnr=1:no_ssim=1:bluray_compat=1:open-gop=0:pic_struct=1:aud=1:nal_hrd=vbr:force_cfr=1:colorprim=bt709:transfer=bt709:colormatrix=bt709:fullrange=off" @ffmpeg.exe -y -hide_banner -loglevel 8 -stats -i "%1" -c:v libx264 -preset veryslow -tune film -profile:v high -level:v 4.1 -x264opts %x264opts% -x264-params %x264opts% -c:a copy -movflags faststart -y -f mp4 "%~n1_.mp4"
Even if you translated those to ffmpeg libx264 it would give you problems. Many of your settings are conflicting or don't make sense
--pulldown 32 isn't supported by some muxers , that could be the cause of skipping. Why would you need 3:2 pulldown anyways when native progressive is supported by BD, unlesss this is for SD encode ? And if it's for SD encode - you wouldn't flag it with bt709.
If this is for BD compatibility (why else would you use --bluray-compat?) , you still need to specify --keyint (max keyframe interval) it's not inclued in --bluray-compat switch. For "24p" a 1 sec GOP is --keyint 24 , so you wouldn't use --min-keyint 25. But you are using 2sec GOP settings (VBV <15,000) so you're allowed to use --keyint 48 -
ok forget the above command
please give a ffmpeg script for this below command
program --level 4.1 --preset veryslow --tune film --pass 2 --bitrate 6000 --stats ".stats" --bframes 3 --b-adapt 1 --b-pyramid strict --ref 4 --weightp 1 --vbv-bufsize 14500 --vbv-maxrate 14000 --subme 9 --psy-rd 1.0:0.00 --no-fast-pskip --tff --pulldown 32 --sar 1:1 --output "output" "input" -
If you used those new settings and still have problems, translating them to ffmpeg won't help. libx264 is based on the same library
Very likely the --pulldown 32 is your problem. For progressive video, you should be removing the pulldown before encoding, not adding it back
And the most common problem for device seeking is a very long GOP interval . lower the --keyint value
FFMPEG: hot to set the "mpeg audio version 1" encoder?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2015, 02:50 -
ts to mpg and also new version of ffmpeg?
By xtal_01 in forum Video Streaming DownloadingReplies: 7Last Post: 29th Jan 2015, 15:04 -
ffmpeg latest version?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 26th Sep 2014, 16:03 -
where I can download ffmpeg version N-35462-g61b1d85 Dec 5 2011?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 13th Nov 2013, 10:45 -
ffmpeg version N-41465-g53dfc38
By ABBrittain in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jun 2012, 17:25
