Hello to all! I was wondering what is the best all around dvd authoring software complete with great quality and can create chapter menus and nice encoding?
Results 1 to 30 of 30
authoring software is not for encoding. you import already encoded mpg-2 and audio, then create menus. for the price dvdlab pro was probably the best. as it's no longer supported maybe adobe encore is the best now.
A software that will work with various types of files with good encoding quality
Give a try to the old TMPGenc Plus, then. My copy runs fine under Windows 7 x64.
BUT BE CAREFUL --- "good encoding quality" requires that the user knows what they're doing
If you're expecting an encoder that will always and magically output "great quality", then you'll be disappointed.
Specially when the subject is DVD-Video, which imposes various restrictions upon what an MPEG-2 encoder can do.
If you don't mind learning some basic Avisynth, then HCenc is the way to go --- very powerful, and very free
No, Nero is not good.
I do a lot of MPEG2 encoding (more than anything else), for a decade now, and the best MPEG2 encoders are in my opinion (in no particular order):
CCE SP3 (not SP2, SP3 has a much, much better encoding engine)
HCenc (which is free)
Procoder 1.5 (version 1.5 is better because later versions have much more aggressive pre-filtering which I don't like)
Procoder is outstanding for interlaced encoding of very hard to encode videos such as camcorder footage and analog tape sources like VHS. Where all the others produce mosquitos or even blocking (even with the bitrate maxed out for DVD) Procoder looks just fine, maybe only a little bit of detail is smoothed. It's not as outstandingly good for any other kind of video though.
CCE SP3 is very good for film sources, I have yet to see another (MPEG2) encoder that can preserve film grain and gradients better. Tends to produce mosquitos if the bitrate is on the lower side though (HCenc would perform better in such scenario).
HCenc has few weaknesses as well as few strenghts, it's pretty well balanced and universal.
Except for Procoder, which doesn't have many settings, you need to tweak the others for optimal results, especially CCE SP3. It's defaults suck.Last edited by Skiller; 28th Jun 2016 at 11:46.
No, Procoder is not free, and nowadays it's impossible to buy version 1.5 because it's so old.
As alreadly suggested you are probably best off using AVStoDVD with HCenc for encoding, and DVDStyler (or maybe GUI for dvdauthor/MuxMan) for authoring. These are easy, free and produce good quality. Get those. -
I have two titles that I don't want to merge to put on DVD can I use those programs to do that?
Yes.
What about menu? If what you want is a menu with two buttons to play the titles enter the menu editor in AVStoDVD.
Then look herecan create chapter menus
https://www.youtube.com/watch?v=w0jIx0dukXU -
Can I use freemake in conjunction with the software I heard the program was good with converting files
What is the best professional DVD Authoring software?
By katieburchett in forum Authoring (DVD)Replies: 17Last Post: 21st Oct 2015, 00:21 -
Best DVD Authoring Software
By mikayd in forum Authoring (DVD)Replies: 22Last Post: 4th Jan 2014, 19:04 -
By devdev in forum MacReplies: 2Last Post: 20th Apr 2012, 05:36 -
DVD Editing And Authoring Software
By garystan in forum Authoring (DVD)Replies: 3Last Post: 14th Aug 2011, 06:11 -
Fast dvd authoring Software.
By Jimbo13 in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2011, 11:14
