  1. PM
    Hey,
    I just got the office US, and my crappy 32 inch philips only supports srt subtitles.
    So the files i got are avi and i downloaded the subtitles i wanted and renamed them, the subtitles won't show so i decided i would just merge them with mkvtoolnix.
    After doing this the files played fine on my pc, so i copied them on my flash drive and tried to play them on my tv, but it says it can't read or find the file.
    I'm all out of ideas, so i need some help.
    The tv i have is the Philips 32pfl5507h/12
    I added a screenshot of the supported mediafiles of the tv
    the mediainfo of the video file:
    PHP Code:
    General
    Format
    /Info                              Audio Video Interleave
    File size
    176 MiB
    Duration
    22mn 26s
    Overall bit rate mode
    Variable
    Overall bit rate
    1 093 Kbps
    Writing application
    : [url=http://www.videohelp.com/software/VirtualdubMOD]VirtualDubMod[/url] 1.5.10.1 (build 2439/release)
    Writing library                          : [url=http://www.videohelp.com/software/VirtualdubMOD]VirtualDubMod[/url] build 2439/release
    Video
    ID
    0
    Format
    MPEG-4 Visual
    Format profile
    Simple@L3
    Format settings
    BVOP                   2
    Format settings
    QPel                    No
    Format settings
    GMC                     No warppoints
    Format settings
    Matrix                  : Default (H.263)
    Muxing mode                              Packed bitstream
    Codec ID
    XVID
    Codec ID
    /Hint                            XviD
    Duration
    22mn 26s
    Bit rate
    956 Kbps
    Width
    576 pixels
    Height
    320 pixels
    Display aspect ratio
    16:9
    Frame rate
    23.976 (23976/1000fps
    Color space
    YUV
    Chroma subsampling
    4:2:0
    Bit depth
    8 bits
    Scan type
    Progressive
    Compression mode
    Lossy
    Bits
    /(Pixel*Frame)                       : 0.216
    Stream size
    154 MiB (87%)
    Writing library                          XviD 1.1.0 Beta1 (UTC 2005-01-16)
    Audio
    ID
    1
    Format
    MPEG Audio
    Format version
    Version 1
    Format profile
    Layer 3
    Mode
    Joint stereo
    Mode extension
    MS Stereo
    Codec ID
    55
    Codec ID
    /Hint                            MP3
    Duration
    22mn 26s
    Bit rate mode
    Variable
    Bit rate
    124 Kbps
    Minimum bit rate
    32.0 Kbps
    Channel
    (s)                               : 2 channels
    Sampling rate
    48.0 KHz
    Compression mode
    Lossy
    Stream size
    19.9 MiB (11%)
    Alignment                                Aligned on interleaves
    Interleave
    duration                     24 ms (0.58 video frame)
    Interleavepreload duration             148 ms
    Writing library
    LAME3.93
    Encoding settings
    : -m j -V 2 -q 2 -lowpass 19.7 --vbr-old -b 32
  2. It says MPEG 4 ASP is supported in MKV. And the Simple@L3 shouldn't be a problem. If the TV can't even find the file there's something else wrong. Put both an AVI and MKV on the thumb drive. Does the TV see either of them?
    Do you have reason to believe the TV will play SRT subs muxed into the MKV? Most require the subs to be in a separate file.
    USA
    bartkrn, , Do not post the same topic on several forums.
    Please do not cross post, once is enough.
    In the future if you wish a thread moved, PM a Mod.
    More double posts will get both threads deleted.
    Moderator redwudz
  4. @redwudz Understood
    I put both files on my flash drive, the avi with the srt file, and mkv with the srt merged in, i know this works because i tried it before with other files.
    The tv sees both the files, the avi works but won't play with subtitles, when i play the mkv it says that it can't read or find the file.
  5. I fixed it by using aviaddxsubs, thanks for the support tho
