are there hdtvs that support this via usb? level 5.1, 10bit, and 16 reference frames
Be mre specific... not sure if you talking about h.264 Hi10P@L5.1 or something else...
Maybe, but that's a very demanding thing to decode if it is H.264. Better to just buy an external media player than to buy a TV based on what things it can play via USB. If it has HDMI, then just about every new media player can output to it.
most likely not. you are lucky if an hdtv will play an mp4 at main@4.1 with 4 ref frames.
Intel should support this, latest NV and AMD GPU also should have no problem to decode this in HW, soon products with Rockchip RK3399 are expected on market and this one should also capable to decode almost everything... Wait few months then buy something.
Number of reference frames x264
By Surlias in forum Newbie / General discussionsReplies: 17Last Post: 17th Mar 2019, 14:32 -
Reference frames and Bframes
By lolman in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2015, 10:14 -
Free High Quality (Benchmark/Test/Reference) Audio Files
By frmys in forum AudioReplies: 3Last Post: 10th Mar 2013, 14:45 -
Change Reference Frames
By Manigorudo in forum Video ConversionReplies: 1Last Post: 22nd Jan 2013, 17:12 -
H.264 reference frames
By grinder_luck in forum ProgrammingReplies: 1Last Post: 13th Jul 2011, 12:39
