i visit the official site : https://ffmpeg.zeranoe.com/builds/
downloaded the 64 bit static build, then checking : ffmpeg -h encoder=libx265
but the supported format is 8 bit only
may i know where to find the ffmpeg with libx265 and 10 bit ?
	If making of avisynth script is a no problem, then you can always unleash a full power of possible settings (using Bepipe, NeroAacEnc, avs4x26x, Mp4box) :
 or use ffmpeg just to load file instead of using avisynth script or making audio and pipe it for the restCode:BePipe.exe --script "Import(^input.avs^)" 2>nul | neroAacEnc.exe -lc -cbr 256000 -if - -of output.m4a avs4x26x.exe -L x265_10bit.exe --crf 22 --vbv-bufsize 20000 --vbv-maxrate 20000 --output output.hevc input.avs MP4box.exe -add output.hevc:fps=%fps% -add output.m4a -new output hevc.mp4
	You probably have to compile it yourself. The commonly available distributed builds typically won't include it
 You can specify 8,10 and 12 bit ffmpeg libx265 with this autobuild
 https://github.com/jb-alvarado/media-autobuild_suite
 (But IMO, it's better to pipe to x265.exe, because the ffmpeg libx265 version is missing a few options)Last edited by poisondeathray; 26th Jun 2016 at 16:12.
  ffmpeg does not apply parameters with libx265By z-machine95 in forum Video ConversionReplies: 15Last Post: 19th Aug 2015, 05:29
  ffmpeg do not apply parameters with libx265By z-machine95 in forum Video ConversionReplies: 1Last Post: 28th Jun 2015, 17:57
  2pass encoding (ffmpeg libx265)By z-machine95 in forum Video ConversionReplies: 18Last Post: 3rd May 2015, 02:43
  does mp4 support 10-bit?By begna112 in forum Video ConversionReplies: 16Last Post: 22nd Oct 2012, 07:29
  FFmpeg Runtime error / FFmpeg git-df82454 32-bit Static (2012-10-03)By MashedPotatoes in forum Newbie / General discussionsReplies: 5Last Post: 6th Oct 2012, 18:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
