Please be gentle with me.
I am a high tech reject who struggles with anything more complex than 'reply' on email even......I am getting into making videos, short clips, not made up stories with people, but product stuff really. It is an extension from my photography that I am having to get to grips with. Up to now I have been using a compact to shoot at the moment, but as I do stills as well and this has to be as well as, not instead of. I have probably made a mistake - too bad, I will have to live with it. I have bought a D4s, so I can do stills and video in the same kit - often I am fighting with other journos and having to get what I can in a media scrum. I am also limited with how much kit I can take - so it isn't ever going to be up to your film making standards, but any help on how to use the DSLR for video and ideas greatfully received.
I am thinking of getting a Came TV 3-axis gimbal to help iron out bumps, for shooting from one moving boat to another, jumping over waves whilst not holding on! So it isn't all plain sailing.
I look forward to progressing my video clip production with your help - if someone tells me how to share video clips on here I am happy to be ridiculed and pulled up.![]()
Results 1 to 10 of 10
Lensflare, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
You asked: "if someone tells me how to share video clips on here I am happy to be ridiculed and pulled up."
I suggest you post one of your videos on youtube then give us the link.Extraordinary claims require extraordinary evidence -Carl Sagan -
Redwudz: I am sorry, my writing incorporated both an introduction and my level of incompetence, Perhaps I should have made two seperate topics. Please accept my apologies.
Treetops: I shall try to load something to You Tube - that is a completely new aspect for me. Unlike the young generation I do not watch You tube or know how to work it. It sounds as though that is another aspect I need to address. Are there any hints or tips you could provide to help me avoid pitfalls with it please?
Many thanks. -
Lots of tutorials on how to upload your video. Go to YouTube.com and input "How to upload to YouTube".
OK, it sounds like you are a professional if you own a D4s and from other details in your OP. As you probably know, video using a DSLR is far from ideal. But you are on the right track by investing in a gimbal. But be aware of some of the limitations in using the D4s for video. First, it is limited to about 30 minutes of recording assuming battery life doesn't get in the way. Second, it only records in HD at a maximum frame rate of 60 fps. Third, it records to a highly compressed non-pro codec i.e. MOV or AVCHD that is likely in 8-bit, 4:2:0 colorspace.
Now, you admitted you are new to video, so maybe some of what I said sounds like martian. Let me see if I can put this in photog terms. If a pro level video camera only offers HD recording into an 8-bit delivery format codec, that is analogous to a journo who uses a camera that only records 8 MP jpegs and no RAW. All the pros grade their footage these days. So you are going to very quickly want at a minimum 4K and 10 bits in a ProRes HQ or similar pro codec format.
Now the D4s has an HDMI-out. So you should be able to get at least 10 bits, 4:2:2, and ProRes HQ with an Atomos Ninja 2 assuming the HDMI-out is a clean signal. In fact the Atomos Ninja 2 was practically invented for DSLR's. But let's face it. HD as an acquisition format is quickly becoming obsolete. And if you really want to compete in the video space, I would think 4K is the minimum entry point right now. For half the price of a D4s body, I can get a Panny GH4 MFT with great glass and start shooting fantastic 4K video tomorrow. And the rumor is that the GH5 later this year will offer 6K video. While at the same time, the Sony A7r II lowlight performance is almost single-handedly redefining video as we know it. But then neither of those cameras have global shutter, and you or your peers might shudder at any hint of jello.
So as you can see, getting an answer to your questions is not easy. I am not sure how you landed on this forum as a place to ask about video. But I would recommend searching the web for reviews and talking with your peers before taking the advice you might get here. This forum is mostly populated by people who rip movies as a hobby versus those who generate their own content. -
I will need translations for the bits emboldened.....into English please! I had to write something here because it didn't let me post the response otherwise...it said my reply was too short or something. I ahve put my bits in red, so it should read sort of sensibly, for gone midnight after having been working since 03.30 this morning.....so don't be offended if it sounds a bit curt. I am knackered. -
Oh - the reason I came here in the first place? Because of the title...HELP VIDEO, I thought that sounded like the sort of place to er, get help wth video!
Videohelp, as in, "I have this video and it..." vs "I am a budding videographer, can you help me...".
I don't really have the bandwidth to answer all your questions, sorry. A little google-fu goes a long way. Just be warned that this camera lacks proper autofocus in video mode and will be less than adequate in an ENG environment and will likely make your viewers seasick, especially with a gimbal, a situation that hasn't improved in even the D5. The D4s is a fantastic camera. A video camera, it is not. But as I said, this is the case for all DSLRs. Also, the Atomos Ninja is not a computer. Again google. And rolling shutter vs global shutter. Again google and youtube are your friends.
But, you already have the camera, so go take some video. Then watch it on a really big screen e.g. 60" HDTV. Then come back here, because you will surely have some questions like, "Why does my video...?"
dslr's have come quite far in video
By aedipuss in forum Newbie / General discussionsReplies: 3Last Post: 31st Jul 2015, 12:11 -
Quality of DSLR microphone for video!
By newpball in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 24th Apr 2015, 02:50 -
All video quality produced by DSLR are identical ?
By AAC in forum Newbie / General discussionsReplies: 17Last Post: 5th Sep 2014, 10:12 -
Flicker on video taken with a DSLR camera.
By prunkdump in forum Newbie / General discussionsReplies: 9Last Post: 5th Oct 2012, 20:30 -
Realistic video resolutions and DSLR's.....
By nateo200 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 15th Sep 2011, 14:15
