hey y'all
like the title says, is it possible to find audio and extract it from any kind of file?
for instance, im making a custom map from a game and there's a ton of audio i can use. i can select the audio track i want to use in the editor, but there's around 1000 or more files and i'd like an easier way of going through them all as the editor isn't that user friendly.
is there a way to search the map building and game folder for audio files that are compressed or grouped together in a single file, say dat or otherwise, and extract them?
regards
Yes ... NO... Maybe... Since you didn't mention the game that someone might be familiar with, it's tough to say. Final fantasy was, WOW wasn't.
These look promising for Dying Light
http://oogus.ru/en-dying-light-the-following-gamerip-soundtrack-2016/
http://forum.techland.pl/topic/5967-accessing-dying-lights-soundfiles-pc/
Can't extract audio from MP4 file
By Alonshow in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jun 2016, 19:01 -
[SOLVED] [newbie] How to extract multiple segments from audio file?
By yetanotherlogin in forum AudioReplies: 6Last Post: 1st Jan 2016, 17:30 -
Automatically find and extract loops in video
By Fred_404 in forum EditingReplies: 1Last Post: 2nd Nov 2012, 11:31 -
[Help] Extract Audio from one file and merge it to another file
By vampelle in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2012, 14:40 -
Extract Audio from RM File without Convert it
By Bruno AUgusto in forum AudioReplies: 7Last Post: 13th Nov 2011, 09:48
