I already posted some of these questions on the capturing forum so feel free to ignore, but it was recommended I ask some of my questions here. I am looking to capture somewhere around 25-40 VHS tapes of home videos to digital. I know, something of a theme around here. I was initially planning on using a Canopus ADVC-55 into my Macbook Pro but after listening to advice from others, it seems that DV is a terrible format to capture VHS to because of the 4.1.1 color and the ADVC-55 is therefore less than ideal. It was recommended that I look into a USB capture stick of some kind to replace the Canopus and these are two of the options I found:
-http://www.bhphotovideo.com/c/product/625264-REG/Elgato_Systems_10020840_Video_Capture...SB_Analog.html
-http://www.diamondmm.com/vc500mac-diamond-video-capture-usb-mac.html
They are both Mac compatible and the VC500 says it captures to Quicktime format and the Elgato to H.264. I know there is a difference between format and container but I don't know the specifics. I don't know how either of these would stack up in relation to the ADVC-55 DV capture as far as quality goes. Idk if it's possible to use these devices with some sort of other Mac capture software (even Premiere?) and get a better format for minimal loss. Seems counterintuitive that the $50 USB stick would be better than the $100+ Canopus box but I'm open to a cheap fix. Ultimately I am looking for reasonable alternatives that capture better than the ADVC-55/DV and the software (Mac compatible) needed to use with it.
Results 1 to 1 of 1
I am looking for a capture device that will capture widescreen format
By zinctrumpet in forum MacReplies: 10Last Post: 3rd Nov 2015, 14:16 -
Best Mac DV Capture Software?
By NA87 in forum MacReplies: 3Last Post: 23rd Sep 2015, 22:16 -
What device/software to stream my cable?
By sitlet in forum Video Streaming DownloadingReplies: 2Last Post: 13th Apr 2015, 20:00 -
Is there a proved working USB capture device with 3rd party software?
By ndep in forum Capturing and VCRReplies: 6Last Post: 18th Mar 2013, 02:55 -
What's a good capture card/device to capture VHS tapes?
By granturissimus in forum Capturing and VCRReplies: 15Last Post: 18th Jun 2012, 23:34
