I was thinking about ripping my whole dvd collection to my PC. I'm using MakeMKV to rip the dvds. But the picture quality ended up to be very poor and grainy.
So I'm wondering if i use the wrong program to rip the dvd, if my dvd drive is poor to rip or if it's just impossible for a ripped dvd, to get the same picture quality, i get when i play a dvd on a dvd-player.
Btw i use Plex to play the ripped dvd on my PS4.
hope someone can help me![]()
Results 1 to 17 of 17
i'd try ripping with Handbrake to create your MKV file's.
These are the PS4 supported formats
MKV
Video: H.264/MPEG-4 AVC High Profile Level4.2
Audio: MP3, AAC LC, AC-3 (Dolby Digital)It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
+1. MakeMKV just rips, it does no re encoding because it doesn't have that capability. Nor does it have good copy protection removal. Ripping and encoding are 2 different things. The picture should be identical. The bit rate of DVD video can be up to almost 10Mb/s ... can your hardware handle that?
Handbrake isn't much good at removing copy protection either ... it's an encoder really, not a ripper as such unless the DVD has no copy protection.
If you want to shrink/compress the file size, which Handbrake does quite well, you aren't going to get the same video quality as the original. Newer codecs like x264 which Handbrake outputs to are better than DVD compliant video but not that much better. But quality is somewhat subjective so whether you'll notice the difference is another question. What sort of screen will you watch it on?
Video encoding isn't simple. There are a lot of good video encoders recommended here but many are really not suited for beginners. Handbrake has a good balance of power and ease of use so it's the one I'd recommend to beginners, along with avidemux. They're both well documented. -
Get dvdfab or anydvd
Rip/Copy the whole complete disc to your hard drive
This will give a folder that has identical files and quality as the DVD
That is now copy decrypted, not protected
Now If you want main movie in a smaller compressed format use handbrake
If you want the same exact quality and file use makemkv
It simply re wraps the video and audio streams into an mkv file format
It does Not compress/shrink the file
It you want small files you are going to have quality loss
The smaller the file the lower the quality
Using h264 encoding and a constant quality setting 'crf 16~18'
Will give a smaller file with good quality, but not a tiny file,
don't use Fast encoding
Use slow encoding, everything is a trade off
Generally you can't get good quality going fast
And always use constant frame rate, not variable frame rate -
No..
Don't blame the hard ware for software problems
If the DVD will play on your PC then there is nothing wrong with your disc drive -
I'm a little surprised at the comments about MakeMKV's decryption capabilities. I haven't run into a DVD yet that it couldn't rip properly. I haven't tried it with many Blu-ray, but it hasn't failed on them either.
A straight rip with MakeMKV will not degrade the video whatsoever. Many have already pointed this out.
What are you using for playback on the computer? -
try playing the mkv file on your PCSo I'm wondering if i use the wrong program to rip the dvd, if my dvd drive is poor to rip or if it's just impossible for a ripped dvd, to get the same picture quality, i get when i play a dvd on a dvd-player.
tell us what that looks like
might be Nothing wrong with the MKV file
might be plex and the PS4, or the PS4 TV combination
what is the connection between the PS4 and the TV
HDMI ? component , straight old A/V ? -
i just found out, that when i play the dvd on my PC with VLC, it looks the same as the MKV file. It's just when i play the dvd on my PS4 it looks so much better.
When i connect my PC to my TV through a HDMI caple and play the dvd it still looks the same as the MKV file.Last edited by chillout; 25th Jun 2016 at 06:27.
What PC?
What display resolution?
What version Windows?
Did you try windows media player, PC only not on TV -
a custom made PC
uses Win 8.
the resolution 1920.1080
windows movie player gives the same picture quality. -
The poor quality you see when you play your files is probably due to interlacing artifacts. Many hardware DVD player (in this case a PS3) can deinterlace when you play a DVD disc. If not, your TV will automatically deinterlace interlaced video it receives from a DVD player (in this case a PS3).
VLC does not deinerlace unless you set it up to do that. Handbrake and Vidcoder don't deinterlace unless you instruct them to do it. I don't use Plex, and have no idea if Plex automatically deinterlaces when it re-encodes interlaced video for streamingLast edited by usually_quiet; 25th Jun 2016 at 14:34. Reason: typo
Ripping a Digital Video Express dvd/DVIX dvd (Circuit City)
By Mr.Delusional in forum DVD RippingReplies: 1Last Post: 1st Jul 2013, 06:01 -
DVD Ripping HELP
By grendel54 in forum DVD RippingReplies: 12Last Post: 23rd Jun 2013, 22:10 -
Need help with ripping a DVD
By Rick Post in forum DVD RippingReplies: 18Last Post: 19th May 2013, 10:28 -
DvD ripping help
By poults1987 in forum DVD RippingReplies: 2Last Post: 8th May 2012, 08:16 -
dvd ripping
By maxone71 in forum DVD RippingReplies: 3Last Post: 22nd Mar 2012, 11:36
