I have Xmedia installed on two different PC's. One an i5 with Win 8.1 and the other an i3 with Win 10. On the i3 there is no option for Quick Sync. Other options are different too. On the 8.1 PC I get only two options under "rate control mode", average, variable and a max bitrate option. On the 10 PC I get average,, 2 pass average, constant quality and constant quantizer with no max bitrate option
It's the same version on both PC's, should there be that much of a difference in options between Win 10 and 8.1?
Yes.
First link in 10, 2nd 8.1
https://i.imgsafe.org/d712e02264.jpg
https://i.imgsafe.org/d70fe3ffad.jpgLast edited by jjis; 29th Jul 2016 at 14:44. Reason: Update
Upgraded the Win 8.1 PC to 10 and now the Quick Sync option is not there.
Intel Quick Sync Encoding
By blaze077 in forum Newbie / General discussionsReplies: 20Last Post: 16th Dec 2015, 20:44 -
BD Rebuilder - Does It Use Intel Quick Sync?
By hogger129 in forum Video ConversionReplies: 1Last Post: 27th Jul 2015, 16:53 -
Handbrake/Intel Quick Sync
By hogger129 in forum Video ConversionReplies: 13Last Post: 9th Jun 2014, 20:55 -
What Authoring Software Uses Intel's Quick Sync Technology
By esoxlee in forum Authoring (DVD)Replies: 1Last Post: 14th Oct 2012, 18:48 -
Intel Quick Sync, will it ever be able to do 2-pass encoding
By Wam7 in forum Video ConversionReplies: 1Last Post: 24th Nov 2011, 16:33
