Hi Everyone,
I'm trying to get a recording of this stream here: www.abc7news.com/live
I dug around the page and found this url:
I've tried several stream recorders to capture that stream with various levels of success. The best one so far is mencoder. I'm using this command line:Code:http://content.uplynk.com/channel/ext/4413701bf5a1488db55b767f8ae9d4fa/KGOwatch.m3u8?tc=1&exp=1466699965226&rn=3070.9982744148&ct=c&oid=4413701bf5a1488db55b767f8ae9d4fa&eid=KGOwatch&ad=watchkgolive&ad.kv=station%2Ckgo&ad.adUnit=midroll&ad.flex=0&ad._v=2&sig=c78c896a2bfd6e87246863a847d1b041d8117f951267d1609b4522192157c7c0
That basically records the show for 1h 10mins to an avi file. Everything works fine EXCEPT: it looks like mencoder captures the lowest quality stream in that broadcast. I know that the KGOwatch.m3u8 has several streams available inside it but mencoder goes for a low quality one. Can I force it to use another stream? How? I've attempted using an url from inside the m3u8 file but I get a forbidden messageCode:mencoder -nocache -rtsp-stream-over-http "http://content.uplynk.com/channel/ext/4413701bf5a1488db55b767f8ae9d4fa/KGOwatch.m3u8?tc=1&exp=1466699965226&rn=3070.9982744148&ct=c&oid=4413701bf5a1488db55b767f8ae9d4fa&eid=KGOwatch&ad=watchkgolive&ad.kv=station%2Ckgo&ad.adUnit=midroll&ad.flex=0&ad._v=2&sig=c78c896a2bfd6e87246863a847d1b041d8117f951267d1609b4522192157c7c0" -endpos 01:10:00 -oac mp3lame -ovc copy -o "c:\temp\abc_news_%date:~4,2%-%date:~7,2%-%date:~10,4%.avi"
m3u8 contents:
results of using a link from the m3u8 file:Code:#EXTM3U #EXT-X-VERSION:5 #EXT-UPLYNK-LIVE #EXT-X-START:TIME-OFFSET=0.00 #EXT-X-INDEPENDENT-SEGMENTS #EXT-X-MEDIA:TYPE=AUDIO,GROUP-ID="aac",NAME="unspecified",LANGUAGE="en",AUTOSELECT=YES,DEFAULT=YES #UPLYNK-MEDIA0:416x234x30,baseline-13,2x48000 #EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=416x234,BANDWIDTH=471244,CODECS="mp4a.40.5,avc1.42000d",FRAME-RATE=30.000,AUDIO="aac",AVERAGE-BANDWIDTH=413250 http://content-ausc2.uplynk.com/channel/0194acb14e714610b2598d206811d951/d.m3u8 #UPLYNK-MEDIA0:704x396x30,main-30,2x48000 #EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=704x396,BANDWIDTH=873267,CODECS="mp4a.40.5,avc1.4d001e",FRAME-RATE=30.000,AUDIO="aac",AVERAGE-BANDWIDTH=710215 http://content-ausc2.uplynk.com/channel/0194acb14e714610b2598d206811d951/e.m3u8 #UPLYNK-MEDIA0:896x504x30,main-31,2x48000 #EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=896x504,BANDWIDTH=1554841,CODECS="mp4a.40.5,avc1.4d001f",FRAME-RATE=30.000,AUDIO="aac",AVERAGE-BANDWIDTH=1249600 http://content-ausc2.uplynk.com/channel/0194acb14e714610b2598d206811d951/f.m3u8 #UPLYNK-MEDIA0:1280x720x30,main-31,2x48000 #EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=1280x720,BANDWIDTH=3328000,CODECS="mp4a.40.5,avc1.4d001f",FRAME-RATE=30.000,AUDIO="aac",AVERAGE-BANDWIDTH=2607154 http://content-ausc2.uplynk.com/channel/0194acb14e714610b2598d206811d951/g.m3u8 #UPLYNK-MEDIA0:192x108x15,baseline-11,2x48000 #EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=192x108,BANDWIDTH=117145,CODECS="mp4a.40.5,avc1.42000b",FRAME-RATE=15.000,AUDIO="aac",AVERAGE-BANDWIDTH=110225 http://content-ausc2.uplynk.com/channel/0194acb14e714610b2598d206811d951/b.m3u8 #UPLYNK-MEDIA0:256x144x30,baseline-12,2x48000 #EXT-X-STREAM-INF:PROGRAM-ID=1,RESOLUTION=256x144,BANDWIDTH=236953,CODECS="mp4a.40.5,avc1.42000c",FRAME-RATE=30.000,AUDIO="aac",AVERAGE-BANDWIDTH=225375 http://content-ausc2.uplynk.com/channel/0194acb14e714610b2598d206811d951/c.m3u8
Code:MEncoder Redxii-SVN-r37872-4.9.3 (x86_64) (C) 2000-2016 MPlayer Team FFmpeg version: N-80353-g8b069b1 Build date: 2016-06-17 01:39:07 EDT Resolving content-ausc2.uplynk.com for AF_INET... Connecting to server content-ausc2.uplynk.com[54.241.162.9]: 80... Server returned 403: Forbidden STREAM_ASF, URL: http://content-ausc2.uplynk.com/channel/0194acb14e714610b2598d206811d951/g.m3u8 Resolving content-ausc2.uplynk.com for AF_INET... Connecting to server content-ausc2.uplynk.com[54.241.162.9]: 80... Server returned 403:Forbidden Failed to parse header. Failed, exiting. Resolving content-ausc2.uplynk.com for AF_INET... Connecting to server content-ausc2.uplynk.com[54.241.162.9]: 80... Server returned 403: Forbidden No stream found to handle url http://content-ausc2.uplynk.com/channel/0194acb14e714610b2598d206811d951/g.m3u8 Cannot open file/device. Exiting...
I also tried ffmpeg to capture that stream with this command line:
The process starts off fine for about 3 seconds (good quality file output) but then it dies throwing this error:Code:ffmpeg -t 00:01:00 -i "http://content.uplynk.com/channel/ext/4413701bf5a1488db55b767f8ae9d4fa/KGOwatch.m3u8?tc=1&exp=1466699377474&rn=1308.5294741229313&ct=c&oid=4413701bf5a1488db55b767f8ae9d4fa&eid=KGOwatch&ad=watchkgolive&ad.kv=station%2Ckgo&ad.adUnit=midroll&ad.flex=0&ad._v=2&sig=ccffcc93c2d2e835e77002b8643aa19f48e52f5bf039c72ed798d35179afa5a6" -c:v libx264 -c:a copy output.avi
Non-monotonous DTS in output stream 0:1; previous: 102, current: 9; changing to 103. This may result in incorrect timestamps in the output file.
Here's the actual code that I see:
Any thoughts?Code:ffmpeg version N-80522-ge0faad8 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 5.4.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib libavutil 55. 24.100 / 55. 24.100 libavcodec 57. 46.100 / 57. 46.100 libavformat 57. 38.102 / 57. 38.102 libavdevice 57. 0.101 / 57. 0.101 libavfilter 6. 46.102 / 6. 46.102 libswscale 4. 1.100 / 4. 1.100 libswresample 2. 1.100 / 2. 1.100 libpostproc 54. 0.100 / 54. 0.100 [aac @ 0000000000666320] element type mismatch 1 != 0 [mpegts @ 00000000006355c0] DTS 0 < 354352 out of order [aac @ 00000000006814c0] element type mismatch 1 != 0 [mpegts @ 000000000064a040] DTS 0 < 354352 out of order [aac @ 0000000002f7f9a0] element type mismatch 1 != 0 [mpegts @ 00000000006a4420] DTS 0 < 354352 out of order [aac @ 0000000002f81b60] element type mismatch 1 != 0 [mpegts @ 0000000003f50680] DTS 0 < 354352 out of order [aac @ 00000000006d7780] element type mismatch 1 != 0 [mpegts @ 000000000444e900] DTS 0 < 354352 out of order [aac @ 000000000334ff40] element type mismatch 1 != 0 [mpegts @ 000000000452ee60] DTS 0 < 354352 out of order [aac @ 000000000062ea00] element type mismatch 1 != 0 [aac @ 0000000002f80ce0] element type mismatch 1 != 0 [aac @ 0000000002f81680] element type mismatch 1 != 0 [aac @ 0000000002f7f000] element type mismatch 1 != 0 [aac @ 00000000006d4c40] element type mismatch 1 != 0 [aac @ 000000000334d400] element type mismatch 1 != 0 Input #0, hls,applehttp, from 'http://content.uplynk.com/channel/ext/4413701bf5a1488db55b767f8ae9d4fa/KGOwatch.m3u8?tc=1&exp=1466699377474&rn=1308.5294741229313&ct=c&oid=4413701bf5a1488db55b767f8ae9d4fa&eid=KGOwatch&ad=watchkgolive&ad.kv=station%2Ckgo&ad.adUnit=midroll&ad.flex=0&ad._v=2&sig=ccffcc93c2d2e835e77002b8643aa19f48e52f5bf039c72ed798d35179afa5a6': Duration: N/A, start: 0.000000, bitrate: N/A Program 0 Metadata: variant_bitrate : 471244 Stream #0:0(en): Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 78 kb/s (default) Metadata: comment : unspecified variant_bitrate : 471244 Stream #0:1: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 416x234, 30 fps, 29.97 tbr, 90k tbn, 60 tbc Metadata: variant_bitrate : 471244 Stream #0:2: Data: timed_id3 (ID3 / 0x20334449) Metadata: variant_bitrate : 471244 Program 1 Metadata: variant_bitrate : 873267 Stream #0:3(en): Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 96 kb/s (default) Metadata: comment : unspecified variant_bitrate : 873267 Stream #0:4: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 704x396, 30 fps, 29.97 tbr, 90k tbn, 60 tbc Metadata: variant_bitrate : 873267 Stream #0:5: Data: timed_id3 (ID3 / 0x20334449) Metadata: variant_bitrate : 873267 Program 2 Metadata: variant_bitrate : 1554841 Stream #0:6(en): Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 128 kb/s (default) Metadata: comment : unspecified variant_bitrate : 1554841 Stream #0:7: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 896x504, 30 fps, 29.97 tbr, 90k tbn, 60 tbc Metadata: variant_bitrate : 1554841 Stream #0:8: Data: timed_id3 (ID3 / 0x20334449) Metadata: variant_bitrate : 1554841 Program 3 Metadata: variant_bitrate : 3328000 Stream #0:9(en): Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 128 kb/s (default) Metadata: comment : unspecified variant_bitrate : 3328000 Stream #0:10: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1280x720, 30 fps, 29.97 tbr, 90k tbn, 60 tbc Metadata: variant_bitrate : 3328000 Stream #0:11: Data: timed_id3 (ID3 / 0x20334449) Metadata: variant_bitrate : 3328000 Program 4 Metadata: variant_bitrate : 117145 Stream #0:12(en): Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 30 kb/s (default) Metadata: comment : unspecified variant_bitrate : 117145 Stream #0:13: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 192x108, 15 fps, 14.99 tbr, 90k tbn, 30 tbc Metadata: variant_bitrate : 117145 Stream #0:14: Data: timed_id3 (ID3 / 0x20334449) Metadata: variant_bitrate : 117145 Program 5 Metadata: variant_bitrate : 236953 Stream #0:15(en): Audio: aac (HE-AAC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 48 kb/s (default) Metadata: comment : unspecified variant_bitrate : 236953 Stream #0:16: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x001B), yuv420p, 256x144, 30 fps, 29.97 tbr, 90k tbn, 60 tbc Metadata: variant_bitrate : 236953 Stream #0:17: Data: timed_id3 (ID3 / 0x20334449) Metadata: variant_bitrate : 236953 File 'output.avi' already exists. Overwrite ? [y/N] y [libx264 @ 000000000567b0e0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [libx264 @ 000000000567b0e0] profile High, level 3.1 [avi @ 00000000032947a0] Using AVStream.codec to pass codec parameters to muxers is deprecated, use AVStream.codecpar instead. Last message repeated 1 times Output #0, avi, to 'output.avi': Metadata: ISFT : Lavf57.38.102 Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv420p, 1280x720, q=-1--1, 29.97 fps, 29.97 tbn, 29.97 tbc Metadata: variant_bitrate : 3328000 encoder : Lavc57.46.100 libx264 Side data: cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1 Stream #0:1(en): Audio: aac (HE-AAC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, 78 kb/s (default) Metadata: comment : unspecified variant_bitrate : 471244 Stream mapping: Stream #0:10 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:0 -> #0:1 (copy) Press [q] to stop, [?] for help [avi @ 00000000032947a0] Non-monotonous DTS in output stream 0:1; previous: 93, current: 0; changing to 94. This may result in incorrect timestamps in the output file. [avi @ 00000000032947a0] Non-monotonous DTS in output stream 0:1; previous: 94, current: 1; changing to 95. This may result in incorrect timestamps in the output file. [hls,applehttp @ 00000000006124a0] DTS 0 < 354352 out of order [avi @ 00000000032947a0] Non-monotonous DTS in output stream 0:1; previous: 95, current: 2; changing to 96. This may result in incorrect timestamps in the output file. [avi @ 00000000032947a0] Non-monotonous DTS in output stream 0:1; previous: 96, current: 3; changing to 97. This may result in incorrect timestamps in the output file. [avi @ 00000000032947a0] Non-monotonous DTS in output stream 0:1; previous: 97, current: 4; changing to 98. This may result in incorrect timestamps in the output file. [avi @ 00000000032947a0] Non-monotonous DTS in output stream 0:1; previous: 98, current: 5; changing to 99. This may result in incorrect timestamps in the output file. [avi @ 00000000032947a0] Non-monotonous DTS in output stream 0:1; previous: 99, current: 6; changing to 100. This may result in incorrect timestamps in the output file. [avi @ 00000000032947a0] Non-monotonous DTS in output stream 0:1; previous: 100, current: 7; changing to 101. This may result in incorrect timestamps in the output file. [avi @ 00000000032947a0] Non-monotonous DTS in output stream 0:1; previous: 101, current: 8; changing to 102. This may result in incorrect timestamps in the output file. [avi @ 00000000032947a0] Non-monotonous DTS in output stream 0:1; previous: 102, current: 9; changing to 103. This may result in incorrect timestamps in the output file.
AnonymousGuest
Livestreamer:
Code:livestreamer --http-header "User-Agent=Mozilla/5.0 (Windows NT 10.0; WOW64; rv:46.0) Gecko/20100101 Firefox/46.0" "hlsvariant://content.uplynk.com/channel/ext/4413701bf5a1488db55b767f8ae9d4fa/KGOwatch.m3u8?tc=1&exp=1466702501183&rn=9638.535741590636&ct=c&oid=4413701bf5a1488db55b767f8ae9d4fa&eid=KGOwatch&ad=watchkgolive&ad.adUnit=midroll&ad.flex=0&ad._v=2&ad.kv=station%2Ckgo%2C_fw_vcid2%2Cc041_6299437393561595251%2Cdatg_yx_bk%2C2HIEq5x499eyjthU&euid=e9cbd587-4291-458c-8a5b-cfa10dd2d4cb_000_0_001_LF&sig=78d6ad45ba8dc8b6dd5b569ecbba4e1e35273cabcf3380238e6af6405e742ab9&ad.cping=1&referer=abc7news.com" best -o ABC7.ts [cli][info] Found matching plugin stream for URL hlsvariant://content.uplynk.com/channel/ext/4413701bf5a1488db55b767f8ae9d4fa/KGOwatch.m3u8?tc=1&exp=1466702501183&rn=9638.535741590636&ct=c&oid=4413701bf5a1488db55b767f8ae9d4fa&eid=KGOwatch&ad=watchkgolive&ad.adUnit=midroll&ad.flex=0&ad._v=2&ad.kv=station%2Ckgo%2C_fw_vcid2%2Cc041_6299437393561595251%2Cdatg_yx_bk%2C2HIEq5x499eyjthU&euid=e9cbd587-4291-458c-8a5b-cfa10dd2d4cb_000_0_001_LF&sig=78d6ad45ba8dc8b6dd5b569ecbba4e1e35273cabcf3380238e6af6405e742ab9&ad.cping=1&referer=abc7news.com [cli][info] Available streams: 108p (worst), 144p, 234p, 396p, 504p, 720p (best) [cli][info] Opening stream: 720p (hls) [download][ABC7.ts] Written 19.8 MB (1m50s @ 184.5 KB/s)
Code:Video: MPEG4 Video (H264) 1280x720 30fps [V: h264 main L3.1, yuv420p, 1280x720] Audio: AAC 48000Hz stereo 128kbps [A: aac he-aac, 48000 Hz, stereo, 128 kb/s]
AnonymousGuest
Currently there is no live stream on this channel, so I can't test it properly. Additionally I can see EXT-X-DISCONTINUITY tags in their HLS playlist. Not a good sign, if you ask me.
Yes, it looks like I might be out of luck with this stream. I tried the livestreamer and it creates a .ts file as expected but it's not playable by vlc. Also, once you get a recording going can you stop it somehow? Other than hitting ctrl+c to interrupt it?
I've tried mencoder too during the actual broadcast but the stream seems to be "jumping" around, at least during commercials, and when it "returns" the audio is way off.
What is EXT-X-DISCONTINUITY and is there a way to deal with it?
Thanks again for your help. -
AnonymousGuest
I can open it with MPC-HC, but the file is not seekable and video playback suddenly stops for some seconds during the commercials. I have no time right now to investigate it further, but it seems to be an encoding issue:
EXT-X-DISCONTINUITY tag indicates an encoding discontinuity between the media segment that follows it and the one that preceded it. -
It works with the higher quality if you specify the appropriate url to mencoder, but the pbs parameter must be included.
AnonymousGuest
Some further investigation: I simply changed the container to MP4. Video playback works fine now (without any interruptions) and the file is seekable.
Command line I've used:
Seems that Livestreamer downloads it correctly and I only have to correct the header / metadata with FFMPEG.Code:ffmpeg -i ABC7.ts -c copy -bsf:a aac_adtstoasc ABC7.mp4
Help with Uplynk HLS/m3u8 from ABC
By LonFirster in forum Video Streaming DownloadingReplies: 26Last Post: 14th May 2015, 15:15 -
record Mtv adria m3u8 playlist
By monk87 in forum Video Streaming DownloadingReplies: 2Last Post: 20th Mar 2015, 13:03 -
How to record a M3U8 streaming on windows 7?
By cypherinfo in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Jan 2015, 15:43 -
How to record part of live stream m3u8(30min)& save it as mp4 using ffmpeg?
By spiderMan007 in forum Video Streaming DownloadingReplies: 0Last Post: 18th Mar 2013, 18:54 -
Record M3U8 HLS stream or cache it: possible ?
By Khalel in forum Video Streaming DownloadingReplies: 4Last Post: 19th Feb 2013, 20:21
