Hello,
Mkvtoolnix seems to work as described except the audio is out of sync in the final mkv file.
The mkvtoolnix troubleshooting guide mentions several symptoms/things to try for fixing problems, but does not mention audio sync.
Anyone experience this and found a solution?
The reason I'm hoping this works is that it's a much faster conversion than Handbrake and the quality appears to be perfect.
Thanks.
Mkvtoonix doesn't "convert" anything. It simply takes the input file(s) and places it into an mkv container. It's (much) faster as it simply reads the input data, and writes it to a new file. Handbrake reads the data, performs a conversion, and then writes a new file.
You can verify this for yourself by opening the original file and the mkv file using a tool such as MediaInfo and compare the video/audio specs.Google is your Friend -
If there's multiple vob files involved are you using the "add files as additional parts" function rather than appending them together in the usual way? Assuming MKVToolNix didn't automatically open them as a single file for you (I can't remember if it can).
If you're ripping DVDs, MakeMKV might be a better option.
Cant merge mkv video and audio with mkvtoolnix?? any ideas?
By kjy in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2016, 12:37 -
Help with batch converting MP4 to MKV with MKVToolnix
By Joe Schmoe in forum Video ConversionReplies: 1Last Post: 11th Jun 2015, 13:53 -
MKVtoolNix adds audio default duration to MKV files that don't have it
By cal_tony in forum Video ConversionReplies: 6Last Post: 20th May 2013, 22:26 -
mkv conversion to dvd sync error
By wolfdogg in forum Video ConversionReplies: 8Last Post: 8th Feb 2012, 11:02 -
Help with avi/mkv conversion to vob with enabled italic subtitles
By hibbs in forum Newbie / General discussionsReplies: 0Last Post: 2nd Oct 2011, 22:18
