I am new to video encoding. And have a few question about TsMuxer 2.6.12;
What does çreate HDMV compatible TS' on the second tab mean... What does it do?
- I remuxed a bluray rip with and without this option. And there's a 2MB difference.
What does SEI / VUI and insertin PPS mean?
- there is little documentation about this. All I know now is SEI/VUI are tag information but it can also affect color-reproduction and AR and stuff
Thanks for any useful help.
HDMV is the authoring mode consumer Blu-ray authoring software uses for creating interactive features, rather than BD-J. An "HDMV compatible TS" would be a transport stream which conforms to the requirements for this type of authored Blu-ray disc.
If you want a detailed explanation, obtain a copy of the Blu-ray spec, or hope one of the few members here who has read it sees your post. There is also some information here: http://www.hughsnews.ca/faqs/authoritative-blu-ray-disc-bd-faq/4-physical-logical-and-...ifications#4.5Last edited by usually_quiet; 23rd Jun 2016 at 16:17.
Thank you, Usually_quiet.
I was skimming the page with information. So the original stream is then modified to suit HDMV authoring purposes like you said
But in what way.. Will it alter I,P,B frame insertion to cater to specific demands or change color information in the tags for the decoder to interpret?
I'm just looking for software that will not alter the original m2ts stream in any way.
MKV subtitles labeled as HDMV don't appear upon conversion to AVI.
By ASimpleLotus in forum Video ConversionReplies: 5Last Post: 10th Jun 2015, 06:49 -
Tsmuxer
By Madness85 in forum Video ConversionReplies: 12Last Post: 13th Jul 2014, 12:49 -
Like tsmuxer...
By fits79 in forum Video ConversionReplies: 12Last Post: 31st Dec 2012, 10:04 -
TSMuxer crashing error code -3 TSMuxer GUI
By petermg in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Nov 2012, 16:21 -
tsMuxer Help Please!!!
By zzNyQuilzz in forum Video ConversionReplies: 3Last Post: 26th Sep 2011, 09:17
