    Aug 2006
    Australia
    Hi using MKVToolNix v9.2.0 on a mac
    Using the appended movies to generate chapters but wondering if these generated chapters can be named after the filename?
    cant seem to find any documentation about it
    thanks
  2. Member Bernix's Avatar
    Apr 2016
    Europe
    User Ronmaz wrote
    Yes you can edit chapter names in an mkv file, even if they are already muxed in. Use mkvmergegui.
    From the menu, select Chapter Editor, then Load. Select your mkv file. Select the chapter you want to rename, type the new name into the "name" field. When finished renaming all your chapters, select Chaper Editor from the menu, then Save to Matroska File, and select the mkv file you want to save it to.
    Hope it helps a bit
