I have 2 raw avi videos with slightly different framerates that I need to fix. So would you guys suggest me with the best solution.
What do you mean by "fix"? And to what end?
i have raw avi video files to join but when trying to join in virtual dub it says "video stream do not share the same sample rate.
first stream 25.004000 samples/secs
second stream 25.0025 samples/secs
i want to fix it. -
AviFrate will let you change the frame rates in the AVI headers. Make backups first as AviFrate changes the selected AVI file. I'd try changing both to 25 fps and see if audio stays in sync.
If you don't want to change them in place use VirtualDub. Open a video. Select Video -> Direct Stream Copy. Go to Video -> Frame Rate and in the "Source Rate Adjustment" field enable "Change Frame Rate To" and set the desired rate. The File -> Save as AVI to create a new AVI file with the rate.
Convert 51.43 fps video in 59.94 fps container to straight 50 fps video
By mr_lou in forum Video ConversionReplies: 5Last Post: 8th May 2016, 11:47 -
frame rate reduction of 29.970 fps to 23.976 fps in megui
By yohanfed in forum Video ConversionReplies: 2Last Post: 28th Jun 2014, 19:15 -
Syncing NTSC 29.970 fps audio to PAL 50 fps video in MKV?
By Merazomo in forum Video ConversionReplies: 10Last Post: 22nd Oct 2013, 23:21 -
By Merazomo in forum AudioReplies: 0Last Post: 17th Oct 2013, 19:09 -
Any decent way to convert higher fps movies to a lower 29.97 fps ? (or othe
By Jonz in forum Video ConversionReplies: 1Last Post: 5th Nov 2012, 02:01
