Hi.
I'm converting a batch of files with Handbrake, but I can't understand why Handbrake doesn't allow to have the same audio settings for all titles? The thing is that I want to use audio track option "auto passthru" for all videos, but as soon as I add them to queue by adding all, then all the videos are added to queue with audio settings AAC (avcodec) 160 bitrate. That means I cannot use add all to queue since the audio settings change back to this default. Am I missing something?
I made a preset with autopass throught and then select folder, choose preset, and add all to queque and it seems to be working. Hope it will works for you too.
And if you want different resolution (same as source) for each video, dont forget to set Picture - Width and Height to none
BernixLast edited by Bernix; 21st Jun 2016 at 08:53.
Hi Bernix!
Thanks for a good advice! Some things are easier than they seem. I made a preset, set it as default and voila! It works! Great!
Need Help! Under audio in Handbrake extra settings.
By botdvd in forum Video ConversionReplies: 1Last Post: 30th May 2016, 04:23 -
Adding titles permanently - Handbrake vs MkvMerge
By FuzMic in forum SubtitleReplies: 2Last Post: 26th Jul 2014, 06:58 -
Handbrake Newbie, recommended video setting, confuse with audio settings
By paizala in forum Blu-ray RippingReplies: 4Last Post: 5th May 2014, 20:46 -
Blu-ray audio settings for handbrake
By edd1234 in forum AudioReplies: 2Last Post: 4th Sep 2013, 11:36 -
Confused about handbrake picture settings (for converting VOB --> MP4)
By VideoThat in forum DVD RippingReplies: 7Last Post: 4th May 2012, 13:11
