Results 1 to 10 of 10
  1. I have 2 mkv from a film:
    Video 1: x264, 1280 x 536, 5727 Kbps, 6.75 GB
    Video 2: x264, 720 x 576, 6382 Kbps, 5.22 GB
    I want delete some scenes with Avidemux.
    Then I want store the film on my pc and watch it later on my pc-monitor (1280 x 1024 pixels).
    To make it smaller, I want with Avidemux new decode the film to x264 with CRF19 or framerate 2000.
    My question for the profis: What is the better video for me (qualitiy), video 1 or 2 ?
    And why (if you want to answer)?
    Thank you very much for an answer and sorry for my ugly english.
  2. The one that looks better.
  3. Member Cornucopia's Avatar
    You may have a problem there: if those files contained ONLY the single video stream with no audio or other streams, your first file amounts to 9887.045 seconds, while the seconds amounts to 6861.256 seconds. So one clip is 3025.789 seconds longer.
    Unless of course you have audio or other streams included. In which case, you haven't given us near enough info to make any determination at all.
  4. Originally Posted by Cornucopia View Post
    If I understand you right (my english is bad), you need more infos?
    (sorry, much text)
    Video 1:
    General
    Format : Matroska
    Format version : Version 2
    File size : 6.75 GiB
    Duration : 1h 48mn
    Overall bit rate : 8 889 Kbps
    Encoded date : UTC 2016-04-28 16:08:51
    Writing application : mkvmerge v3.4.0 ('Rapunzel') gebaut am May 15 2010 09:38:20
    Writing library : libebml v0.8.0 + libmatroska v0.9.0
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 48mn
    Bit rate : 5 727 Kbps
    Width : 1 280 pixels
    Height : 536 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.348
    Stream size : 4.18 GiB (62%)
    Title : 720p
    Writing library : x264 core 148 r2692 64f4e24
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=17 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5727 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : Yes
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Mode : 16
    Format settings, Endianness : Big
    Codec ID : A_DTS
    Duration : 1h 48mn
    Bit rate mode : Constant
    Bit rate : 1 509 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Frame rate : 93.750 fps (512 spf)
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 1.15 GiB (17%)
    Title : 5.1 Sound
    Language : German
    Default : Yes
    Forced : Yes
    Audio #2
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 1h 48mn
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Frame rate : 31.250 fps (1536 spf)
    Delay relative to video : 2s 0ms
    Stream size : 149 MiB (2%)
    Title : PsO Line
    Language : German
    Default : No
    Forced : No
    Audio #3
    Format : DTS
    Format profile : ES Matrix / Core
    Mode : 16
    Codec ID : A_DTS
    Duration : 1h 48mn
    Channel(s) : 7 channels / 6 channels
    Channel positions : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
    Bit depth : 24 bits
    Delay relative to video : 11ms
    Language : English
    Default : No
    Forced : No
    Text #1
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Language : German
    Default : Yes
    Forced : Yes
    Text #2
    Format : UTF-8
    Title : English-Forced
    Language : English
    Default : No
    Forced : No
    Menu
    00:00:00.000 : en:00:00:00.000
    00:03:04.726 : en:00:03:04.726
    00:05:53.019 : en:00:05:53.019
    00:09:30.820 : en:00:09:30.820
    00:13:19.090 : en:00:13:19.090
    00:16:48.716 : en:00:16:48.716
    00:20:12.545 : en:00:20:12.545
    00:22:06.408 : en:00:22:06.408
    00:27:09.628 : en:00:27:09.628
    00:31:58.959 : en:00:31:58.959
    00:36:51.709 : en:00:36:51.709
    00:41:06.172 : en:00:41:06.172
    00:44:45.766 : en:00:44:45.766
    00:46:56.605 : en:00:46:56.605
    00:50:10.966 : en:00:50:10.966
    00:53:18.028 : en:00:53:18.028
    00:55:33.038 : en:00:55:33.038
    00:59:07.753 : en:00:59:07.753
    01:03:05.240 : en:01:03:05.240
    01:07:06.439 : en:01:07:06.439
    01:09:15.568 : en:01:09:15.568
    01:12:29.720 : en:01:12:29.720
    01:16:46.393 : en:01:16:46.393
    01:20:43.714 : en:01:20:43.714
    01:25:53.398 : en:01:25:53.398
    01:31:03.792 : en:01:31:03.792
    01:34:46.973 : en:01:34:46.973
    01:39:52.737 : en:01:39:52.737
    Video 2:
    General
    Format : Matroska
    File size : 5.23 GiB
    Duration : 1h 43mn
    Overall bit rate : 7 220 Kbps
    Encoded date : UTC 2016-06-21 02:26:29
    Writing application : MakeMKV v1.9.10 win(x86-release)
    Writing library : libmakemkv v1.9.10 (1.3.3/1.4.4) win(x86-release)
    Original source medium : DVD-Video
    Video
    ID in the original source m : 224 (0xE0)
    Format : MPEG Video
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : Variable
    Codec ID : V_MPEG2
    Codec ID/Info : MPEG 1 or 2 Video
    Duration : 1h 43mn
    Bit rate mode : Variable
    Bit rate : 6 382 Kbps
    Maximum bit rate : 9 800 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Bit depth : 8 bits
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.616
    Time code of first frame : 00:01:35:00
    Time code source : Group of pictures header
    Stream size : 4.62 GiB (88%)
    Language : English
    Default : No
    Forced : No
    Audio #1
    ID in the original source m : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Codec ID : A_AC3
    Duration : 1h 43mn
    Bit rate : 448 Kbps
    Stream size : 332 MiB (6%)
    Title : Surround 5.1
    Language : English
    Default : Yes
    Forced : No
    Audio #2
    ID in the original source m : 189 (0xBD)-130 (0x82)
    Format : AC-3
    Codec ID : A_AC3
    Duration : 1h 43mn
    Bit rate : 384 Kbps
    Stream size : 285 MiB (5%)
    Language : German
    Default : No
    Forced : No
    Menu
    00:00:00.000 : en:Chapter 01
    00:02:56.240 : en:Chapter 02
    00:05:37.640 : en:Chapter 03
    00:09:06.520 : en:Chapter 04
    00:12:45.440 : en:Chapter 05
    00:16:06.480 : en:Chapter 06
    00:19:21.960 : en:Chapter 07
    00:21:11.160 : en:Chapter 08
    00:26:01.960 : en:Chapter 09
    00:30:39.440 : en:Chapter 10
    00:35:20.200 : en:Chapter 11
    00:39:24.240 : en:Chapter 12
    00:42:54.840 : en:Chapter 13
    00:45:00.320 : en:Chapter 14
    00:48:06.720 : en:Chapter 15
    00:51:06.120 : en:Chapter 16
    00:53:15.600 : en:Chapter 17
    00:56:41.520 : en:Chapter 18
    01:00:29.280 : en:Chapter 19
    01:04:20.600 : en:Chapter 20
    01:06:24.440 : en:Chapter 21
    01:09:30.640 : en:Chapter 22
    01:13:36.800 : en:Chapter 23
    01:17:24.400 : en:Chapter 24
    01:22:21.400 : en:Chapter 25
    01:27:19.080 : en:Chapter 26
    01:30:53.120 : en:Chapter 27
    01:35:46.360 : en:Chapter 28
    *********** END
  5. Nobody can tell you which video is better by examining statistics. You have to LOOK at the videos with your eyes to see which is better.
  6. Member Cornucopia's Avatar
    ...but one can make a few assumptions.
    The 2nd video looks to be a MKV-rewrap of standard MPEG2 DVD material. It contains anamorphic display (either 16:9 native or ~2.4:1 padded to 16:9). It is, however, NOT as efficient as AVC/h264 (and you are incorrect in your original post: video2 is NOT encoded with x264 encoder).
    It may be an original, or it may be a first generation PAL version from a film. Video #1 could be a first generation from a film (after inverse telecine), or it may be a 2nd generation from Video #2. It's also possible, but not likely, that Video #2 is a 2nd gen from Video #1.
    Note that V2 is VBR. V1 is NOT, it is CBR, which is a shameful waste of good bitrate. If it IS a 2nd gen from V2, it makes no sense to do all that other stuff (IVTC, crop-to-native-ultrawide-squarepixel) and then waste the compression on CBR.
    Of course, there is a 5 minute discrepancy between the 2 videos - that's a lot to have to correct & resync! Better to GO BACK TO A KNOWN GOOD SOURCE, and work from there.
  7. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    The Conch Shell has spoken.
  8. Originally Posted by Cornucopia View Post
    ... you are incorrect in your original post: video2 is NOT encoded with x264 encoder...
    Oh, sorry. It's a big error from me.
    Much thanks for all helpers in this threads.
  9. So which did you decide was better? And how did you come to that conclusion?
  10. Originally Posted by KarMa View Post
    [Attachment 37466 - Click to enlarge]
    42
