I have a .wmv video that plays normally at a moderate level (call it a 5 on a scale of 1-10 in home theater DVD player terms) for the first 45 seconds and then it decreases to around 1-2 for the remaining 5 minutes. My goal is to play the video on my home theater DVR's HDD without manually increasing the volume by roughly 45%. It seems that extracting or ripping the audio will be no problem (please recommend program(s) for a newbie) but I'm not sure about increasing the volume. Thank you!
	You may try to recode wmv video (somehow limited popularity codec) to something more popular and apply dynaudnorm filter that will prevent large level difference across stream.
	Audacity is not able to extract the audio from a video file unless you add the ffmpeg source plugin.
 http://manual.audacityteam.org/man/faq_installation_and_plug_ins.html#How_do_I_downloa...ort_Library.3F
 Once you have imported the audio, mark the low volume section and use Effect -> Amplify to increase its volume. Then use File -> Export Audio to save the result.
 Then you'll need to mux the video from the original file with the new audio with an appropriate muxing tool.
	If you use windows then bellow script should work - modified one of my scripts, tested and seem to be OK. AVI is not the best container but... you can try mp4 or mkv - not sure about limitations of your environment.
 Code:@setlocal @set /a cput=(%NUMBER_OF_PROCESSORS%*3)/2 @SET x264opts="crf=22:vbv_maxrate=20000:vbv_bufsize=20000:qpmin=4:qpmax=69:level=4.0:keyint=250:cabac=1:threads=auto:sliced_threads=0:slices=-1:no_psnr=1:no_ssim=1:bluray_compat=1:open-gop=0:pic_struct=1:aud=1:nal_hrd=vbr:force_cfr=1:colorprim=bt709:transfer=bt709:colormatrix=bt709" @if not exist %cd%\out (mkdir %cd%\out) @ffmpeg -y -threads %cput% -hide_banner -loglevel 32 -stats -avoid_negative_ts 1 -i %1 -c:v libx264 -preset slow -profile:v high -level:v 4.0 -x264opts %x264opts% -x264-params %x264opts% -vf colormatrix=bt601:bt709 -c:a libmp3lame -q:a 4.5 -af "pan=stereo|FL < FL + 1.414FC + .5BL + .5SL|FR < FR + 1.414FC + .5BR + .5SR,aresample=resampler=soxr:osr=48000:dither_method=0,dynaudnorm=p=1/sqrt(2):m=100,firequalizer=gain='if(gte(f,24),0,-INF)+if(lte(f,15999),0,-INF)':accuracy=1:fixed=on" -f avi "out\%~n1.avi" @Pause
  increase volumeBy loa909 in forum Newbie / General discussionsReplies: 8Last Post: 5th Jan 2016, 11:29
  MP4 volume LevelBy rizy in forum AudioReplies: 0Last Post: 27th Nov 2015, 04:19
  Sound level increase...By ziggy1971 in forum AudioReplies: 13Last Post: 7th Feb 2015, 21:31
  Increase volume of audio filesBy shans in forum AudioReplies: 12Last Post: 22nd Jun 2012, 22:35
  vob 2 video + audio then increase audio volume then recombine to vob or mpeBy indyram in forum Authoring (DVD)Replies: 6Last Post: 14th Dec 2011, 02:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
